12 Speaker premium or Mark Levinson
I am beginning talks with my local dealer about the purchase of a 2010 RX450h. I would prefer to have the Mark Levinson audio system, but none of their vehicles have this option, and the inventory manager is saying to get that, that a 3 month order would have to be made.
I even went to the Lexus site to build my 450, and the ML system was not listed as an option, although i can spec this out on kbb.com when i build one over there. I guess its just a regional thing.
Now to my question:
Can someone who has heard both the 12 speaker premium, and the Mark Levinson systems tell me your impressions of it? Is the ML system worth the extra cost?
Thanks in advance
Now to my question:
Thanks in advance
The ML system in my previous car had nineteen speakers and way too much low-end power. I find the premium system in this car very adequate, and much easier on my aging ears. The midrange works quite well for this confined space. I toyed with the idea of going with ML, but only because of the additional DVD-Video & HDD capability. If you're a real audiophile, then you should consider it.
Is the mark levinson better? Yes
Is it $1600 better? No
The 12 speaker is fine and many reviews say that it is much better than the standard 9. the RX has never had a really good ML system because of the way the cabin is. THere is just too much space in the cargo area which attributes to the lack of "surround" sound.
No, I don't play soccer!
Get the ML. I've never been a fan of the stock stereo system. This is the first time I went for the upgrade and don't regret it.
And look at it this way, if you do a special order, you get what you want. Took four months for me.
Thanks for the info. I am an audiophile in a sense. I love a great sounding system. I do like bass response too, but clean clear and crisp mids/highs are my weakness.
I will see if they will try to locate a vehicle for me at another dealer that has the ML in it. Not too sure if I want to wait 4 months just for the audio system. If there were more options that would be affected overall, then maybe I would do the order. If a ML RX can't be located, I may just go with the premium. I am going to the dealer tomorrow to test drive one, and will see how the 12 speaker setup sounds.
Like most systems that have the sub-woofer in the rear, the bass response is richer when the listener's position is biased to the rear of the vehicle. So shift it back & forth, and side to side to see what works best for you - and bring along your most discrete CDs...
I have the ML and I did listen to the 12 speaker first. The ML is better, is it $1600 better not sure about that. It does have bass and the sound is equal through out the car. You do need to bias it toward the rear.
Now to my question:
Thanks in advance
Now to my question:
Thanks in advance
I'd think it much better for you to listen, rather then seek opinions. I've been happy with my premium systems over the years.
so you're dealer won't trade with another dealer? there have to be some RXs in the southeast that your dealer can trade for...
I've read the ML sounds good in some models and not so hot in others.The RX being one of those 'others'.
I haven't heard the system in a RX but owned a GS with ML and was very dissapointed.
In the GS,the center channel drowned out the other sppeakers and there was no volume adjustment.Listen to the ML before you buy it.I didn't and wasted $2K and was reminded of that every time I got in the car.
My son in law has a LS460 with ML and it sounds great.
The 12 speaker system sounds good and much better than the standard system on my '09 RX.
The 12 speaker is a option over the standard 9 speaker which isn't very good.
I think it will be difficult to find an RX with the ML option sitting in a dealer's lot. I certainly had no luck in tracking one down when I was looking. If you want it, and can be patient, go for the special order and get whatever other options you would like. However, the 12 speaker system isn't bad and I suspect you could live with it if necessary.
After having read in these forums about "premature" failures of some ML branded sytems in older Lexus models, I decided I'd rather save the $$ and put it towards an after-market audio upgrade, if desired.
From an audiophile perspective, I would say the 12 speaker system is adequate, but definitely not "high-end." Mids are excellent, highs a bit rolled off, and bass fairly "muddy". For the $$, I would expect the ML system to sound better, but I never had the chance to compare.
I don't spend a lot of time commuting, and after one month, I feel the 12 speaker system is "good enough" for the road. I might consider adding a sub, or upgrading the entire system down the road, but only if I could do so for <$1000. When I want real music I have my Conrad-Johnson/Martin Logan Summit setup at home
If you do spend a lot of time commuting and listening, I would definitely recommend auditioning the ML upgrade option before deciding. Your dealer should be willing to find the car you want, or custom order one for you. Unfortunately, it took a lot of arm-twisting and game-playing for me to ultimately get what I wanted.
The one feature that is sorely lacking in the Lexus ML system is a sophisticated and usable equalizer. Without it, the system is limited to basic low/mid/high control not much different than a humble AM/FM radio. I suspect the legal department doesn't want the operator to fiddle around too much while driving. The end result is an impotent system that can't be tailored to individual tastes.
I appreciate all the replies. I went to the dealer today and test drove, and talked about what I wanted. They did not have a 12 speaker system on the lot. The 450 I test drove had the 9 speaker, and I didnt even care to listen to that one. I ended up deciding to go with one that has the 12 speaker system and is still on the boat on its way over. I'll post info on it in a new thread.
I hope this thread doesn't turn into what kind of speakers/amps/subwoofers should I get.
I've been there, done that with my 330. It started with changing the speakers to adding amps, subwoofers, crossover, clean sweep and soundlinq. The only thing I didn't change was the radio itself. I was pretty happy with the setup for the most part but it was kind of expensive. Now I thought about adding a subwoofer and amp to the 450h. For now I have decided ML isn't so bad after all. My wallet is pretty happy. And I really need to act my age
