RX 450h change indications
Hi,
I imported a rx 450h from the states to belgium.
Can anyone tell me how to change the airco indicator from farenheid to C°, change the tire presure monitor from psi to bar and the miles couter to km.
thanks
thanks
I think it should be accessible via the Multi-information Display (viewable inside your dash). Try pressing the switch on the steering wheel and flip through until you see the customization options.
Those are three options that cannot be changed by the owner, however your local dealer may be able to do so. The only user selectable Imperial to Metric options are on the Navigation system and HUD output, unless someone can prove otherwise.
thanks for the answers but i work at a local belgium dealer, and i can't change it with the intelligent tester of lexus. im seaching for a other way to do it.
in the multi display you can only change gallon/miles to L/km
I stand corrected, you can change Miles to Kilometers in the Nav. Go to Setup -> General -> then look for the miles/km conversion option. I just saw it last night. I haven't looked for the psi/bar conversion...but Good luck!
Toggling the HUD's display from imperial/metric can only be accomplished via the MID.
I forgot about that shortcut. Thanks!
EDIT: The beauty of this shortcut is it can be done on-the-fly. The MID way requires the car to be stopped.
Hi,
At least thermometer display from F to C is not possible. I asked this from Lexus Customer Service. They have C display in Canada and F display in USA. Even in old Toyotas you could change the display but not in brand new Lexus. It is weird. I suppose it is the same with the tire pressure monitor.
Sakke
Sakke
ThumperPup
RX - 3rd Gen (2010-2015)
11-30-22 10:49 AM
kmcgillivr
RX - 1st Gen (1999-2003)
05-02-06 05:07 PM
