Last edit by: IB Advertising
Browse all: Lexus IS Lighting Guides
- Lexus IS: How to Install Illuminated Scuff Plates
Step by step instructions for do-it-yourself repairs
Illuminated door sills and installation instructions
#76
I changed my puddle lamps as well. I went with 6000k halogen fog lights and they look better than the stock. I like the look of yours, good match. My illuminated door sills are slightly whiter than the door courtesy lights, not enough to get upset about, I think they look good.
Did you go with 5 LED bulbs in the doors?
#80
If I can get the white lit,yes.I want to match the LEDs in the doors.
Going by their pic,Sewell seems to have the blue lit.
When I talked to Darrel at Sewell,he said "it’s my opinion they’re blue, but then again can be construed as white."
I want a definite they're white like yours answer.Till then...
Same part# for the 350 and 450 so I'm thinking Sewell has the blue.Maybe someone here will order a set and let us know.
#81
No, I don't play soccer!
Joeb, you can go first
I'm torn between white or the white/blue since I plan on changing the interior lights soon. They'll probably be white. So it makes sense to have everything including the puddle lamps the same color. This has turned into quite the adventure
Keep me posted.
#83
Keep me posted.
I'm very tired and don't understand your second sentence.
#84
Check out this forum:
https://www.clublexus.com/forums/rx-...ted-sills.html
Has pics of both 350 and 450 door sills.
#85
#86
Keep me posted.
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
It's an easy upgrade and are definitely noticeable when you get in or out of the vehicle after hours.
Maybe I preferred the blue because my SCs have the whiteish illumination sills and I wanted something different.
Take the plunge you guys....the water is fine.
lar
#87
Those sills are white lit with no blue at all which would match my white LED bulbs I installed in the lower doors .
The 67910-48070-B0 and 67920-48070-B0 part#'s are different than the two listed in this thread.We have 48060 and 48080 on this thread which is weird.
The sills are $50 more at Carson but more important to me is I'd like to use my couple of hundred Lexus credit card points which I don't know if I could with Carson.
I'll email Sewell and see if those part #'s are available through them.
These are on that thread and MEP's has the same ones.White lit!!!
![](https://i148.photobucket.com/albums/s14/jtrue28/IMG_0012.jpg)
![](https://i148.photobucket.com/albums/s14/jtrue28/IMG_0011.jpg)
