"Check AWD System" Warning Message (merged threads)
#211
^^ Thanks for pointing out those videos. Looks like removing the cowl and windshield wiper assembly is indeed the way to access the three rear spark plugs, although the working room still looks to be very tight back there. I have monster-sized hands and I am not looking forward to doing this job when the time comes. Having the right socket wrench extensions and swivels seems to be crucial as well.
For anyone who has already done this job on a 3rd Gen RX350 via the cowl / wiper assembly removal method, please post your tips and tricks here. Much obliged.
#212
#213
Another detailer blew the fuses
picked up car and pull out and discover I'm in limp mode.
Took it to mechanic I trust around the corner. They tried to reset the system didn't work so said they would run the diagnostic tool but they were closing so couldn't do it then.
I look up the issue online and find the same scenario multiple times.
Mechanic was speculating all the possible causes. Got them to check fuses next day, 3 blown with burn marks. Replaced them and problem resolved .
#214
#215
'12 rx350 Check AWD light
When I tried to start my car (kids kept doors open for a while on an 3 years old A/M AAA battery), first I got check AWD system, TRAC OFF messages and car wouldn't start.
Called AAA Roadside assistance and they cranked up the battery. Car started but Check AWD System, TRAC OFF, and Check Engine light wouldn't go away. I started driving and car has no power or whatsoever, it just rolled according to the road conditions (rolled down on a slope, crawled on high hills, I needed to get home as it's already 12:00 midnight and I was only 5 miles away).
Is it because of the week battery or do I have a major problem that I need to spend a lot to get my car on road again?
#216
Please don't let your imagination run wild.
Did the AAA service determine that you need a new battery? Did the tech connect an OBDII diagnostic tool? Have you had a chance to charge up your depleted battery after the boost?
You can visit auto parts store and they can test your battery and charging system as well as give you OBDII test results for free. These readers are fairly cheap and you can read and clear error codes..
A health battery is a must, before pursuing any error codes.
Salim
Salim
Clutchless (04-29-24)
#217
AAA did say I needed a new battery. I'll sure have someone run the diagnostics today. Thanks for your response
Salim
Salim
#219
Just get a new battery and all those codes will go away.
The AAA driver already advised that that is what you need. It died on you once. Keep driving on a weak battery and you will kill your alternator as it works too hard trying to charge the worn out battery. As Salim said, random codes such as those you posted are another sign of a dying battery.
Do not waste time or money on further diagnostics unless they persist for a couple of weeks after the new battery is installed. Sometimes it takes a while for these random codes to self clear.
#220
****UPDATE******
So, I finally have my car back on road!!!.
After the freelance mechanic changed the throttle body and couldn't program it I took the car to dealer. Dealer found a couple of blown fuses. They changed the fuses, recalibrated the computer for a flat hourly fee. The Service manager said they checked everything and no problem with the car battery.
Drjohnbee
RX - 3rd Gen (2010-2015)
07-07-14 12:13 PM
2006, 330, 350, 4wd, awd, check, check awd system, check engine light on, checkawdsystem, checkengine, engine check light, highlander, hybrid, lexus, rx, rx 350, rx300, system, toyota, trac off, vibration, wad, warning
