LED light bulb replacement for the 2010+ RX
Old 08-10-10, 08:18 AM
talwang
talwang's Avatar
Originally Posted by E12ic46
where are the clips for the rear. I really don't want to damage it anymore..popping off the clear piece does no help because you can't get to the bulb like mentioned above.
Just tape your screwdriver before you proceed.
Old 10-16-11, 07:27 PM
howardha98
howardha98's Avatar
Hi..
I am struggling trying to remove the rear dome light for RX350 2011. I am able to pry off the clear plastic cover. But I have a tough time getting the whole unit off so I can pluck out the bulb..Anyone knows how to remove the rear passenger dome light assembly? I'm grateful for your help ..If possible, please post some of the pics so I can follow your instructions
Thanks
Howard..
Old 10-16-11, 08:02 PM
djkidkris
djkidkris's Avatar
Originally Posted by howardha98
Hi..
Thanks
Howard..
Yeah that's probably the toughest bulb to replace. I'm positive Anita feels the same way about it . Once you get the lens off try using latex gloves to get a better grip to pop the bulb out. You won't need to pop out the entire housing.
Old 10-17-11, 03:03 AM
kitlz
No, I don't play soccer!
kitlz's Avatar
Yeah, that rear dome bulb cover is an itch to remove. Same with the bulb itself. I tried to remove the whole assembly but I couldn't figure out how it's held in there. It took me a while before I found the right tool. I wound up using a thin metal tool two inches wide, I think it's for a lathe, to release the cover and needle nose pliers to loosen the bulb.
Old 10-17-11, 07:58 AM
howardha98
howardha98's Avatar
Thanks everyone for posting your suggestions for removing the rear light dome bulb.. It's quite a challenge to pry that bulb out..
Thanks
Howard
Old 10-17-11, 08:55 AM
2k11sfrx
2k11sfrx's Avatar
I use duck tape to roll around two of my finger and just squeeze and pull for the rear domelight bulb its easy !!
Old 10-17-11, 09:23 AM
2k11sfrx
2k11sfrx's Avatar
BTW Looking good talwang , love how it look !! I also swap my whole entire car out lol ...
Old 02-07-14, 02:46 AM
Juni14Ayal
Juni14Ayal's Avatar
Thanks for post. I ordered the replacement lights for the cargo area, and the ones received were slightly bigger than OEM equipped lights, and do you know the code for these LED lights? I have seen 3021, 3022, 3175, etc. Any help will be appreciated.
thank you.
Old 02-10-14, 08:31 PM
TaninAuto
Sponsor
TaninAuto's Avatar
The cargo area LED's should be festoon style, 32mm I'm guessing. The rest of the lighting should use T10 or 168 wedges. Your owners manual should list the bulb sizes needed.
We have most, if not everything you need.
http://www.taninautoelectronix.com/F...estoon_led.htm
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
Old 02-11-14, 07:27 AM
VVRX
VVRX's Avatar
thank you.
The cargo area uses festoon 29mm bulbs. Check out PrecisionLed.com. They have kits designed to fit the Lexus RX.
Old 02-17-14, 02:55 AM
Juni14Ayal
Juni14Ayal's Avatar
Thank you for the feedback, I will look for the festoon 29mm bulbs. I have also had issues replacing the fog bulbs and the ones received do not match OEM design, the new ones I have received does not lock, having to return them. Any suggestions?
thank you.
Old 02-17-14, 04:28 PM
Mike813
Mike813's Avatar
Does utilizing LED for the rx cause any power drain issues? I've ordered a set of LED interior lighting from a forum vendor for my infiniti previously and noticed the lights stay on slightly on he panel boards. It might not bug other people but it sure did with me to the point I changed them out. Just wanted to see if these did the same.
Old 02-17-14, 06:05 PM
kitlz
kitlz's Avatar
thank you.
Juni14Ayal, what kind of fitment problem did you have with the fog lights? Also what kind of bulb did you go with? I've tried a few brands and types and didn't experience any issues. For HID, go with XenonDepot, a CL vendor. VLEDS carries some great LED bulbs. And stick with Philips for halogen. That's what I have in my fog lights now. They were purchased from Nigel, also a CL vendor.
No power drain issues whatsoever after 3 1/2 years. I have VLEDS in my 450h and the lights go completely off when they're supposed too. The dome lights and puddle lamps don't come on as smoothly as OE bulbs. But it's not bad at all.
Old 02-24-14, 08:23 PM
TaninAuto
Sponsor
TaninAuto's Avatar
We have the 29mm festoon LED's. $2.99 each.
__________________
262-456-4147
Old 02-25-14, 08:58 AM
wakame
wakame's Avatar
is the stock LED lights closer to 6000K or 8000K?
Quick Reply: LED light bulb replacement for the 2010+ RX
