Daytime Running Lights
05-15-11, 06:22 AM
Did u check the setting menu?
you should check the menu setting by using the menu button on the steering wheel. there is a menu for DRL on or off.
05-15-11, 07:17 AM
Quote:
Originally Posted by
steve4rx
Hey, Thanks so much. Forgot a bout this. Yes it was set to OFF. just turned it back on and it's on even on "parked"
12-29-12, 12:43 PM
Does anyone have a part number from this DRL module that disable the "DRL OFF" switch?
Thanks.
tkrussell
12-14-23 07:37 PM
popeye84
06-30-16 01:14 PM
Maratonez
01-27-16 03:29 PM
Lexs400
03-25-05 03:50 PM
gapxguy
Lighting
01-04-05 10:08 PM
2010 ,
350 ,
canada ,
daytime ,
dim ,
drl ,
gs ,
hs250h ,
import ,
lexus ,
lights ,
nav ,
off ,
program ,
running ,
rx ,
turn
