Spontaneous Electric Motor Noise
Here's the new mystery. The 2010 RX350 has been parked in the garage for about six hours. I'm working on another project in the garage and suddenly hear the sound of an electric motor start to run. I look around outside to see if a neighbor is working with some power tool- nothing. Could it be an appliance in the house- no. I go back out and walk around the garage a bit and notice the sound is coming from the rear underside of the Lexus. I poke my head near the rear wheels where it is the loudest and just as I go seek the creeper to investigate the noise stops. All told, this motor ran for about four or five minutes. Anyone have an idea what this might be?
Yes, something to do with the emissions control. I think it's the charcoal canister being purged or something. My 2006 RX400h does the same thing. I think there's even a TSB regarding this..
its the emissions evap system purging itself. my service rep check last time i was in and said it was normal even after the car has been sitting. i think its even mentioned in the manual somewhere.
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
This noise is described on page 22 of the 2010 RX350 Owner's Manual in a section that's aptly named "Noise from under vehicle after turning off the engine".
During the canister purge's cycle, the system draws this vacuum through the carbon canister and allows fresh air to enter it. The vehicle’s Powertrain Control Module (PCM) determines the duty cycle of the purge solenoid. The purpose of allowing fresh air into the carbon canister is to oxygenate the stored hydrocarbons (HC) before they enter the engine, allowing for more efficient combustion. The mixture of HC and air being purged from the carbon canister is monitored closely by the PCM to assure that the lowest possible effect on vehicle tailpipe emissions is maintained.
Tcagle
12-09-16 11:06 AM
Mhobizal
ES - 6th Gen (2013-2018)
11-21-15 09:59 PM
mmade22
01-28-14 01:26 PM
mmade22
RX - 3rd Gen (2010-2015)
10-05-10 04:15 PM
