power trunk door
Old 10-22-11, 06:47 PM
  #136
MEP7557
MEP7557's Avatar
^ That is not true. Mine is programmed for the auto open and it will open with the FOB and all the doors locked. In fact when you open the hatch with the FOB it will not unlock the doors, only opens the hatch.
Old 10-22-11, 07:01 PM
  #137
BatmobileX
BatmobileX's Avatar
Do you have to wait for the hatch to completely close after pressing the button on the key fob before you can lock the car? Because I've been standing there waiting for the hatch to completely close before pressing the lock door button.
Old 10-22-11, 11:06 PM
  #138
MEP7557
MEP7557's Avatar
Yes, you have to wait for it to completely close.
Old 10-23-11, 09:08 AM
  #139
Nogee
Nogee's Avatar
Default set up is different
I did a controlled test on driveway this morning.
FOB - Doors locked: Unlock doors on the FOB twice, then open the hatch works. FOB does not open hatch unless the doors are locked.
Hatch Button - Doors locked. One touch on the rectangular button unlocks doors AND opens hatch with one touch.
Hatch Button - Doors unlocked. Round hatch button unlocks the doors as usual.
Update: When inside the car and doors locked, the power hatch button on the dash requires the doors to be unlocked first.
I guess there are different combinations for this set up.
Old 10-23-11, 01:45 PM
  #140
LexRexBlue
LexRexBlue's Avatar
Round button on the hatch will lock the doors, too.
Old 10-31-11, 03:11 PM
  #141
BatmobileX
BatmobileX's Avatar
You know, I am not a fan of manually closing and opening the hatch. It gives too much resistance and I feel like it's damaging the mechanism.
Old 09-15-12, 03:12 PM
  #142
momogala
momogala's Avatar
Hey guys. Need help. I have a 2010 RX350 and took it to the dealer to program the rear trunk to power open when I press the long button on the trunk. Right now it will unlock it but will not power open. They said it is not possible. They hooked up the scanner to it and said not possible. Can anyone help? This was at Lexus of Orlando
Old 09-15-12, 03:23 PM
  #143
kitlz
No, I don't play soccer!
kitlz's Avatar
Find another dealer that knows what to do. The option was available beginning on the '11s as one of the Lexus Personalized Settings (LPS). Can't imagine the directions would be different. There are a few of us here with '10s that had it programmed.
Old 09-15-12, 04:50 PM
  #144
LexRexBlue
LexRexBlue's Avatar
Dealers have been doing it on the '10s since '10. How is it possible for Lexus service not to know this? Are NJ Lexus Service Dept. just more up to date??? I know they send them for training often! It makes you question how qualified are some of those service departments.
Old 09-15-12, 07:08 PM
  #145
MEP7557
MEP7557's Avatar
Out here in Arizona I had no problem, the dealership did not even question my request. I have a 2010.
Old 09-25-12, 01:04 PM
  #146
CharlieP
CharlieP's Avatar
Default Frustrated in Austin
I asked my dealer Lexus of Austin to program the rear rectangular button to unlock all doors and power up the door on 1st touch. They said power couldn't be controlled from door on 2010 and 2011 models. When I got the car back they programmed it to only unlock the side doors on first touch and unlock rear door on 2nd. arg!
Old 09-25-12, 01:34 PM
  #147
kitlz
kitlz's Avatar
Charlie, press and hold the rectangular button for 2-3 seconds to see if the tail gate will open up. On mine the doors will quickly unlock and then the tail gate opens under power.
Old 09-25-12, 02:51 PM
  #148
CharlieP
CharlieP's Avatar
Thank you, but still No dice.
Press and hold for 3+ seconds only unlocks all side doors
Press twice unlocks rear door manual lift.
My MFG Date is 04/09. Anyone else confirm similar build date and power lift from gate button?
Called Lexus Customer Care and they in turn called in a technician. They told me it's an option that can only be programmed at the factory. *hand to forehead*
Old 09-25-12, 10:27 PM
  #149
EMSLEXUSRX
EMSLEXUSRX's Avatar
I'm sure I've posted this before, but they were able to do it at Lexus of Tampa Bay over a year-and-half ago for me.
Old 12-13-12, 10:40 AM
  #150
Hemi57
Hemi57's Avatar
Is this programming (power open) specific to hybrid? Can it be done to a regular RX. Dealer here in Detroit said my 2012 RX350 is not equipped with this option.
Quick Reply: power trunk door
