what is correct tire pressure?
Isn't there a sticker on the driver's side door jamb and isn't on the tires themselves?
That being said, I think I've got mine at 34-35 right now. When the weather turned cold I started getting tire pressure low warning so I pumped them up.
I've been thinking of using nitrogen, but I understand it's $10/tire and they install green valve stem caps. Not sure how the green would go with the blue themed hybrid colors!
Im pretty sure my door jam says 36psi but I could be wrong. The instrument cluster gauge reads 36-38 psi depending on when I check.
I had nitrogen on my 330 and didnt notice much of a different. I replaced the green valve stems with black ones, haha
Just Google nitrogen VS. air. Don't be fooled, dealers found another way to empty your pockets. Air we breath is 79% nitrogen. That small difference is a scam to your wallet. My car came with it and I won't be paying $8.00 per an adjustment anytime soon. What the heck is this BOTOX! There are plenty of credible scientists who state its all a scam. perhaps a car on a race track doing 180mph for several hours may benefit, even that is questionable. Safe your money! This is paying for high octane gasoline are the scams. Our gasoline is watered down with so many additives and yet engines keep running just fine.
Dealer pumps to about 35 psi even though this is higher than the recommended pressure listed on the door jams.
I believe pressure listed on tire sidewalls is max recommemded pressure or something like that.
The sticker on my 2010 RX 350 FWD made in 06/10 states 32 PSI all around for all loads. Pumping a few more in isn't going to make much difference, but if the ride gets choppy try cutting it back to 32 and see how it rides/handles.
