Lost my BiXenon Function
Hi guys, can someone explain to me why my high beams function stopped working after I changed my OEM HIDs to 6000K. Was there something that I accidentally unhooked or is the replacement HID unable to support BiXenon function? By the way I upgraded my HIDs to Garax 6000k..
Guys i somehow got it to work again. It started last night when i was driving home when i started to try testing how the high beams would look like on the road with the new HIDs on. When I started to push the light stick forward to turn it on, it would not activate and the fog lamps stay open. I tried this several times but still the high beams stayed on low beam mode. When I tried pulling the stick toward me it would activate the high beams (flashing mode) but would not turn on if i push it forward. When I was trying to ask other forums somebody mentioned that high beams dont work on AUTO mode. So when I turned the light dial to the ON mode (3rd click from OFF), high beams work again
Lexus must have set it up that high beams would not work on AUTO mode aside from using it only flash other vehicles Also the brand of the bulbs would not matter as long as you use a correct D4S bulb since like what Jim said our high beams are based on a shutter that adjust for the low and high beams
P.S. DO YOU HAVE ANYTHING TO BACK YOU UP?
P.s seems like most of you "wanna believe" it's bi-xenon. Lol.....
As far as I know the HID equipped RX350 are BiXenons, i didnt see any other replaceable bulb when I replaced my HID bulb; on the otherhand our DRLs are only DRLs and dont function as high beam unlike on the 2nd gen IS models.
There is one bulb on each side period. The intensity does not change, a shutter moves up and down for high and low beam.
there is nothing wrong with your highbeams. As Panyo noted, when you are in AUTO mode and you push the stick forward, you are activating the auto high beam as well, and if there is sufficient light on the road, it will not turn on. You have to go to a dark alley with no lights in order for them to come on in auto mode.
I did read your quote and your still completely wrong. Do YOU have any proof!
Like others have said there are three types of headlight assemblies for the RX
1. Halogen 2. Bi-Xenon HID 3. LED
So please stop propagating misinformation.
Thanks,
correct me if Im wrong, but bi xenon usually refers to two xenon bulbs per headlight, as in the high beam and low beam all use bi xenons. As a result, the RX doesnt have a true bi xenon set up, and they usually mislabel their website as such. im guessing other Lexus literature will be incorrectly stating this too
