Yellow bulb to white LED
Old 07-02-17, 04:40 PM
  #151
kitlz
No, I don't play soccer!
kitlz's Avatar
Alpha777z, glad the rear dome bulb replacement went well. The LED puddle lamps did have the dimming effect. They were maybe not as smooth as the halogen bulbs, if that makes sense. It wasn't a big deal to me considering the massive improvement. The LEDs are considerably brighter. And they were still going at five years when I traded it in for the 4RX.
Alfa777z (07-02-17)
Old 07-02-17, 09:19 PM
  #152
Alfa777z
Alfa777z's Avatar
Thanks a lot, Anita.
I'll buy Sylvania LED 194 bulbs tomorrow from local AutoZone and install it right away.
I have also just bought three LED bulbs from vleds. This time those are for trunk/cargo area, but they look kind of fat. Do you think it will fit and work ok? However the length is ok 29mm. Here's a link for the trunk bulbs
http://www.vleds.com/shop-applicatio....html?___SID=U
BTW I started a new thread you might want to check it out...
https://www.clublexus.com/forums/rx-...ml#post9913619
Good luck!
Old 07-03-17, 10:22 AM
  #153
kitlz
kitlz's Avatar
Sorry, I can't remember exactly what size I wound up getting for the cargo area. I think it was 29mm. It took three attempts before I found festoon bulbs that fit. It just might be a matter of making slight modifications.
Good luck!
Great job. I have a few threads of my own on replacement fog lights. Too bad Lexus waited until 2015 to make LED standard. That's an option but you should be happy with the Philips. It's what I wound up with in the end. And they were halogen too.
Old 07-03-17, 11:08 AM
  #154
Alfa777z
Alfa777z's Avatar
Thanks! Yes I should be happy with Philips. I usually don't buy cheap stuff from e-Bay. I'm not too rich, so I can't afford to buy cheap stuff from China over and over again, because they fail too often, plus I don't have time to replace it constantly. The investment should last accordingly with the price.
BTW I have just added the new pics to that thread.
Old 01-14-18, 08:55 AM
  #155
gonzalu
gonzalu's Avatar
Any VIDEOS on how to replace these bulbs on the 2016 RX-350 F-Sport? I don't want to break anything LOL
I got both regular LEDs and CAN Bus LEDs coming. I believe the parts are #194 bulbs?
Thank you in advance.
Old 01-15-18, 01:04 PM
  #156
smknkeyz
smknkeyz's Avatar
Someone in the 4RX forum may know? Once it's time to upgrade the ride, I'll look into it for you.
gonzalu (01-15-18)
Old 01-15-18, 02:22 PM
  #157
gonzalu
gonzalu's Avatar
LOL... OK, let me try over there...
Old 09-04-18, 05:30 AM
  #158
phi2hot4u
phi2hot4u's Avatar
Default DIY Parking and Reverse light bulb
hi I was wondering if you have a diy for he parking and and revere light bulb replacement?
Thanks
Old 09-04-18, 03:09 PM
  #159
ribster197
ribster197's Avatar
Can someone recommend a white bulb to yellow bulb for fog lights. ( 2013 rx 350)
part # , brand...…..
Old 09-05-18, 05:49 AM
  #160
smknkeyz
smknkeyz's Avatar
I did a full morimoto LED fog light swap. They have yellow LED colors too. I would highly recommend it. I believe I got mine from theretrofitsource.com.
Old 09-05-18, 02:59 PM
  #161
ribster197
ribster197's Avatar
Default fog light
thanks Smknkey.
is it easy to install? play and play?
Old 09-06-18, 06:27 AM
  #162
smknkeyz
smknkeyz's Avatar
Originally Posted by ribster197
thanks Smknkey.
They sell sealed projector units, so they are 100% plug and play and look exactly like factory. Where the fog lights are on my f sport was a little bit of a pain to get to, but it was doable. You have to loosen the wheel well shielding to access the lights behind the bumper cover.
Old 09-06-18, 02:22 PM
  #163
ribster197
ribster197's Avatar
Default fog light
Thanks Smknkey,
I will order and install them, I will let you know!!
Old 07-13-19, 03:06 PM
  #164
Faculty
Faculty's Avatar
Location: Louisville: KY Vehicle: Lexus RX-350 Name: Justin
Originally Posted by papaalex
Just wanted to show some of my light mods, thanks to all for the DIYs posted and bulb suggestions in this forum.
Daytime running lights
http://store.ijdmtoy.com/9005-HB3-LE...9005_sku45.htm
I think this one will work too but i am not sure
http://www.v-leds.com/Exterior-LED/D...-p7652845.html
Love this, did you have to re-wire anything or was it simply popping in a bulb?
Quick Reply: Yellow bulb to white LED
