The 3RX Gas Mileage Thread
Old 06-30-12, 12:48 PM
  #106
Alpy64
Alpy64's Avatar
Originally Posted by Cruiter
There is a great free app I found out about here in C/L. It's called Fuelly if you search your app store. You can enter the data when you fill up, or just write your current odo reading on your receipt and enter on your PC at home. I've used it just three times now and the results are below. For the record, it's within .2 of what Watson's computer says he's getting . I'll keep track of that over time.
I use another one "spritmonitor" a German app which is also nice for recording consumption and producing graphs.
Yours look really interesting as well 😉
Old 06-30-12, 07:11 PM
  #107
BP1203
BP1203's Avatar
My AWD 2012 has 1,400 miles on the clock, averaging 18.3 mostly city miles. Took a 300 mile trip and got 21.6 highway, cruising speed around 75 mph.
Old 07-01-12, 11:19 AM
  #108
markrivers
markrivers's Avatar
Originally Posted by peh
'12 AWD with 5000 miles and I get 16-17 mpg city and 21-22 mpg highway. Dissappointing.
well to start with, you have AWD which gets 1mpg LESS than the FWD.
how fast is your highway speed? if you're doing 75 and up.. forget it.
is there a lot of traffic on your city driving? that will bring down the mpg as well.
the only way you can get 30ish on an SUV is by changing the engine to a 4 cylinder.. like what Mazda is doing. the Skyactive technology.
Old 07-01-12, 11:54 AM
  #109
BobBass
BobBass's Avatar
And when you do that, you might as well get out of the vehicle and run alongside, especially a vehicle as heavy as an RX.
Old 07-01-12, 12:58 PM
  #110
Cruiter
Cruiter's Avatar
Actually my RX 450h has long term mileage in excess of 30 mpg and weighs a tick under 5K with the hybrid system and traction batteries. Plus it's total HP output is 297 .
I will admit that a caveat is not exceeding 70mph which sucks more from any car. No way to prevent total wind resistance.
Old 07-01-12, 01:12 PM
  #111
dctex99
dctex99's Avatar
Default Yes
65mph is the magic number.....seems slow; but if you have the time it is kind of fun to see how high you can get it!!
Old 07-02-12, 01:12 PM
  #112
GoHuskers
GoHuskers's Avatar
Just refueled today. Low fuel light came one with 8 miles left on the cruising range, it only took 13.992 gal for 430 miles so that is a little over 30 mpg. However, the tank average showed 27.9 mpg, what gives? This is the second times I saw this mishaps using the same gas station but different pump.
The spouse's 350 AWD is average about 19 mpg .
Last edited by GoHuskers; 07-03-12 at 02:42 PM. Reason: Mistyped 27.9 mpg for 17.9 mpg
Old 07-02-12, 08:36 PM
  #113
DunWkg
DunWkg's Avatar
GoHuskers,
Just checking, but you were reading the "after refueling" and not the "average" since reset? Seems like quite a disparity. Do the odometer readings look correct? Is the average speed close?
Old 07-03-12, 06:13 AM
  #114
GoHuskers
GoHuskers's Avatar
Originally Posted by DunWkg
GoHuskers,
Yes, the after refueling, NOT the lifetime average. I reset the lifetime average every 3 months and the last time it showed 28.9 mpg and it is about the same now. May be this pump stopped before the tank is really full; however, the Cruising range show 441 miles after I fueled up.
I have not reset the average speed for a long time and I notice it shows 33 mph for quite a while (comparing to my 350's 18 mph average speed) - I don't understand this Average Speed number at all - how does it calculate?
The last tank with 430 miles which has about 220 miles hiway (70-75 mph) and the rest are city miles.
Old 07-03-12, 09:25 AM
  #115
Cruiter
Cruiter's Avatar
Even when you're stopped at a traffic light of stop sign and the ignition is on it's calculating. That's the only true measure. I only use it if I'm on a trip and want to know the average speed for the whole trip.
Old 07-03-12, 09:53 AM
  #116
DunWkg
DunWkg's Avatar
I think sometimes it seems we say we spend most of our time on a trip going 65-75 mph, as an example, but the 65-75 is more a peak not the average. The averages I've seen are usually way below what I believe I've done. (traffic, rest stops, food stops, slow cars, cops)
GoHuskers, I usually reset the two averages at the same time as I'm evaluating both averages for the same period of time.
Unfortunately, none of this discussion has determined the reason for your disparity.
Old 07-03-12, 11:05 AM
  #117
GoHuskers
GoHuskers's Avatar
Next time I refuel I will use this same pump again and again to see if it just stopped too soon last time.
Old 07-03-12, 11:59 AM
  #118
mac12
mac12's Avatar
My 2010 FWD Rx is averaging 22.3 on premium gas. It has almost 19k on it and that is for its life.
Old 07-03-12, 01:59 PM
  #119
Cruiter
Cruiter's Avatar
I believe your reference to 'my' quote "The Only True Measure" is your 'own' disparity. I think you confused my quote as someone else. My mpg is in excess of 30mpg.
Old 07-03-12, 02:31 PM
  #120
DunWkg
DunWkg's Avatar
Jim,
The "disparity" comment was not direct at you. Your excellent mileage is well documented and I respect your efforts to get and maintain good mileage, in addition to your helping others reach good mileage.
The disparity is in the numbers GoHuskers mentioned on his last fill up.
Using those numbers from GoHuskers:
Car thinks:
441 Cruising Range
17.9 MPG
24.6 gallons in the tank? (not likely)
Calculations:
441 Cruising Range
30 MPG
14.7 gallons in the tank? (very possible)
Quick Reply: The 3RX Gas Mileage Thread
