dual pane glass
If you look down on the window glass you'll easily be able to see if it's single or dual pane. The duel pane will be like two pieces glued together. My front drivers and passenger door glass was replaced by Lexus because it was only single pane. The 2 ply glass has really cut down on the wind noise I once had. I don't think "laminated" appears on either single or 2 ply window glass.
installation instructions of glass breakage sensor from sewell lexus parts
http://lexus.sewellparts.com/pdf/PT39848090.pdf
