Buzzing sound when engine is off
#46
Wow. That makes a lot of sense. The key is usually in the back hall within about ten feet of the car. And yes it sounds like a pump running. I belong to several car owner sites and I have never received such consistently useful feedback as I do on this one. Thx.
#47
by my experience (2013) the key has nothing to do with it. If the tank is at a certain level, the pump comes on, period....thankfully this forum saved me when I first heard the problem 8 years ago...I have the 1000 page manual, but how do you look up "buzzing sound?"
Ddk912 (01-03-22)
#49
#50
mine has definitely run for more than five seconds, but has never been a problem....the car is nine years old and trouble free.
Note the comment above from wcoffman on 1-06-17 in which (on page 24) the owner's manual explicitly states you may hear the sound for "several minutes" and it does not indicate a malfunction....that's been my exact experience, I hear this fairly often....
#51
Summary, know your vehicle and if there is an abnormal behavior, have it looked at the next service.
Salim
#53
If you have had this from day one then I too would say ignore it. If on the other hand it has progressively developed then have it checked. One of the problem [I am not saying you have an issue] area is with ABS where a pump has to constantly build pressure if there is an internal leak. If this issue is not addressed in time, it shortens the life span of the pump.
Salim
Salim
#54
I was able to get the buzzing to stop be opening and closing my rear hatch. Makes no sense but it works.
I read a lot of guessing on this thread. What is truly causing this, what is its purpose and should I be trying to stop it?
#55
as mentioned several times above in the thread, try reading your manual. Can't believe this is still a mystery to some.
landonm86 (06-08-22)
#56
Our 2010 RX350 has started making a series of three loud rapid clicking noises after starting the engine and again a few minutes after the engine is turned off.
The sound is coming from behind the middle of the dash.
The attached video records the sound. This noise happens 3 times then it stops.
Any tips would be greatly appreciated. Love this vehicle!
Thanks so much for your reply!
Problem solved.
We backed off the panel below the glove box and then opened the glove box and removed the filter. The cavity was filled with grass from a nest. Once removed the noise stopped.
Hope to get a few more years with this vehicle!
Problem solved.
Buddy888
NX - 1st Gen (2015-2021)
06-15-15 05:57 PM
eclipse604
03-05-08 11:35 AM
