2011 rx350 body side moldings dealer?
Is that about right for this kit . Do they have a sperate one just for side molding or should I buy it myself from the vender here. its $160 without the club discount and $133 with it for the color matching. Thanks
I would only do the side moldings. That seems like a lot of money that the dealer is charging. If you are handy you can do them yourself, they come with complete instructions.
Welcome to the Club
Welcome to the Club
Don't do that deal. It sounds like a rip-off. You can buy the side moldings from Sewell Lexus for around $100. That's what I did and had my Toyota dealer install them. The best I remember I had $205 in them otd. I don't know about the door edge guards.
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
![Talking](https://www.clublexus.com/forums/images/icons/icon10.gif)
I ordered the side moulding from Sewell and installed it myself. It is not too difficult if you prep the area with some prep solvent and use masking tape to set the proper height. There is a left and right moulding so you should tape them on temporarily first to ensure you have the proper one for each side. It took about an hour to install both sides. It looks great and will help to protect against door dings.
Good luck!
Jim
Good luck!
Jim
I had a local body shop put my on it is the same one the the Lexus dealer uses in was $20 tip to the man that put them on. I have use this shop before but the Toyota shop was going to be $100 to put them on told me it was 2 hours they did it in less than 20 minutes
They look great
You can do it yourself, its very easy just follow the instructions.. Just have somebody there to assist you and hold the other end. And even if you miss the mark by a few millimeters, NOBODY would notice
Besides even the ones who install it in body shops may miss the mark occasionally ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
Here is my "masterpiece" I could have missed by few millimeters![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
![](http://i5.photobucket.com/albums/y166/papaalex/RX/IMG_3269.jpg)
Does the prep solvent actually prep the surface or just clean it. The last install I did on another car, I just use dish washing detergent to romove the wax and the polish and then wipe it down with rubbing alcohol. Some say there is a prep solvent on the market that actually make the surface of the metal tacky.
My side molding installer used this which made the surface of the paint tacky for better adhesion.
Does come off easily with alcohol if need be.
Body shops use 3M promoters.
Automotive Adhesion Promoter
for 3M Acrylic Foam Tapes
Increases bonding strength of any double sided tape.
For plastic trim attachment with 3M Acrylic Foam Tapes.
http://www.paulfrancispaint.com/servlet/Detail?no=21
![](http://www.paulfrancispaint.com/catalog/3m%206396.jpg)
Just bought it at ebay store for $109
http://cgi.ebay.com/ebaymotors/2010-...0#ht_791wt_935
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
