2011 RX350 - Using 2 different bluetooth devices together?
I am using a Verizon Droidx with the RX350 for hands free and multimedia audio via bluetooth.
Problem I am having is that I am also using the Droidx via Bluetooth connected to my AT&T TL8109 Analog phone to answer cell phone calls from my landline.
However, when I leave the office and get into the car the RX350 no longer seems to recognize the Droidx so I can't talk hands free or listen to audio via bluetooth.
Is there a way to priortize the bluetooth devices so when I start the RX350 that bluetooth connection becomes the higher priority and then it would disconnect the bluetooth to the AT&T Desktop phone.
I want to use bluetooth for both my desktop phone and in the RX350 but need help on getting them to work together.
Please let me know. Thanks.
The way it works is that if two phones that are recognized are in the car, it will choose the phone that was previously in the car working solo. If you are carrying two phones at the same time, then try leaving the ATT phone in the office and just starting the car with the Droid long enough that it will sync with the Droid. Then go back and get your ATT phone, and when in the car at the same time, it should connect to the Droid
Perhaps I've confused there.
There is only one Droidx cell phone. I have the Droidx connected via Bluetooh to my AT&T Desktop Phone (TL86109) and then I leave the office and go into the garage to start the RX350. I want the Droidx to disconnect from the AT&T office phone and then connect to the RX350 once the car is turned on.
Is there a way to do that?
Don't think the RX can pair to a phone that is already paired to another phone. Sounds like you need to tell the Droid to disconnect from the ATT and pair with the car. Simply turning off the Droid and turning it back on while sitting in the car might do it.
Or try turning off the bluetooth on the ATT before entering the car.
It seems to be working now although I have not done anything. It connects when I turn on the car and then connects again to my AT&T desktop when I get back into my office.
Glad I did not do anything :-)
