Anyone here have burnt/dirt problem with clear bra on fog light lenses?
executive matchup
I installed clear bra awhile back, including the fog lights. Now I'm having a problem with the clear bra - it seems like there is "burnt" look to the plastic film? So when you look at the fog lights when it is on, the light comes out blurry and not sharp as it should be. I thought it was dirt, so I tried washing it; also tried using a bug/tar remover...both didn't help. Short of going back to my clear bra installer to remove and reinstall again, anyone have any recommendations on how to get the film clear again? ![Dunno](https://www.clublexus.com/forums/images/smilies/13879dunno.gif)
front facing:
![](http://i56.tinypic.com/2urpkw7.jpg)
left front fog light:
![](http://i55.tinypic.com/1zp6r1k.jpg)
left front fog light (close up):
![](http://i51.tinypic.com/t7btk3.jpg)
right front fog light (close up):
front facing:
![](http://i51.tinypic.com/23496h.jpg)
Sorry to see your problem with your fog lights. I think "cloudy" is another term to describe your problems?
Mine is running well without problems for more than 5 years. I have had film on fogs and headlights (with HID low beam, Piaa halogen high beam) and did not encounter the problems.
May I ask what brand of film was used by your clear bra installer? Some film manufacturer specifically do not recommend the film to be installed on lights. For Ventureshield ultra, it is okay.
Hope it help.
Hope it help.
Just spotted the following post which mentions the fog lens cover is actually made of glass. Now I will see your problem in a different light. Maybe film on lens cover made of glass could cause problem?
https://www.clublexus.com/forums/rx-...attered-5.html
My IS has plastic lens cover for the fog and the film looks okay after 5 years. I have to observe what will happen to my RX after some more driving.,
executive matchup
Hope it help.
Hope it help.
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Stormforge,
Seems that glass lens is the culprit. I just have the clear bra on the fog for less than 2 weeks. How long did it take you to discover the problem? I will keep my eyes on.
executive matchup
nope, they are oem bulb. i've been wanting to swap bulbs over to like what kitlz et al have done, but i've never had the time to do any bulb swaps.
yeah, i think you're right. the fact is, i always have my low beam headlights on with my fogs when i drive at night.
Stormforge, I am contemplating the application of a clear bra for our new RX and I am studying the pictures you attached of your car. We are also considering Ventureshiesd. Do you know if the seam just below the fog light is a standard practice for this brand or does is depend on the installer? I did not know what to expect, but I thought that the film would not be cut out around the sensors and lights, but rather go right to the very edge of the lights, sensors, etc. Also, I notice that at the edges of the film, it seems to collect dirt. Is this difficult to clean and must you do something special to the bra when you wash the car. Sorry if I am off topic a bit but I am attempting to collect as much information as I can prior to having this done. Thanks!
No, I don't play soccer!
cafpaf, I have the seam under the fogs too on my clear bra, 3M. I think that's pretty standard. The dirt accumulates here and there but I'm not too concerned. Lifetime warranty
Storm, I can't say I have the same problem. It's illegal to put film on the fogs and headlights in my state. Sometimes I wonder if driving is legal with all the laws
I probably wouldn't do it anyway with the HIDs in there. Might be time to revisit your installer to address the problem, sorry to say
Very clean RX BTW. Aurora White, don't see that color ever around here.
executive matchup
my problem was that i could not wash the RX for weeks or months at a time (winter season followed by rainy season, etc). so my RX got dirty and dirt builds up. if you wash your car frequently, you shouldn't have a dirt problem with the clear bra.
as for diffculty of cleaning, if it does get caught at the edges, it is very difficult to remove (if not impossible). from five feet away or more, you will not notice the dirt, only when up close.
washing the RX, just wash normally as if you had no clear bra on.
yeah, i'm trying to book an appt with my installer. he did confirm by saying that the film has to be peeled off the fog light. the film on the low beam LED headlamp is ok, which i assume is because the LEDs generate low heat compared to the halogen (?) bulb for the fogs.
Yep - the film is overheated. This happens on some vehicles even with OEM lights. We just filmed a new WRX and the same thing happened to the fogs. We always recommend not films the lights with higher wattage bulbs or even aftermarket HID -many have the bulb very close to the lens - adding to the heat.
Noticed the installation of the PPF was hand cut on the paint around the sensors and fogs. We recommend a kit that fits the front of the vehicle so you can insure you do not score the paint. You will only notice the razor cuts in the paint AFTER you remove the film. Just some thoughts for you DIYers.
