New Daytime Running Lights (LED)
#31
I'm tempted to give these a try. They come with brackets and the price is right.
http://www.superbrightleds.com/cgi-b...w8hf_specs.htm
#35
No not yet. I think I am going to try and recess them further back in that area. I haven't gotten around to doing so because of the heat. It's too darn hot. Will update when I do that. They have not budged one bit though.
#36
OK I braved the oppressive temperatures in the garage and moved the lights back further. They are there for good now. I had to cut into the black plastic to get them to go back further. They are also screwed in now. They look a lot better sunken back in, not so 'add-on' looking. On to the next project.
#39
Anita
I just said that, LOL, nothing in mind but I'm sure something will come up. I have a feeling the 12's will have the illuminated homelink buttons and of course I will have to have those. Depending on the cost. No glow in the dark stickers for me.
#40
#41
I used self tapping sheet metal screws, less likely to crack the housing. The passenger side there is lots of support but I did have to cut a lot more plastic out of the way. The drivers side is fine as I left the middle fin and screwed up thru that, then had to put a brace pushing down on the light to keep it aligned with the other one. If I knew it was going to be this much trouble I would have skipped this mod. It's done now though. I am easy to spot.![Over Here](https://www.clublexus.com/forums/images/smilies/overhere.gif)
I can't believe Lexus would give the ES350 and the 250h the illuminated buttons but not the RX. Maybe gen4.
#43
Anita
What would you like pictures of? I thought I posted quite a few. I am more than willing to post more. Let me know what you want to see.
Later
Michael
Later
Michael
#44
No, I don't play soccer!
