Gas Tank Capacity
Old 04-23-12, 03:00 PM
  #31
Sevn86
Sevn86's Avatar
Originally Posted by ejm3
I try to fill up sooner rather than later simplye becuase it makes me feel better to "only" put $50 in gas in the tank rather than $75 ;-)
lol...thats a good way to look at it.
Old 04-23-12, 04:35 PM
  #32
markrivers
markrivers's Avatar
i have the same "trick"
in my case it's $35, and i always pay cash hence the additional savings in the pump (10 cents/Gal)
Old 04-23-12, 05:57 PM
  #33
dctex99
dctex99's Avatar
Default How far to empty
My Lincoln town car had this same guage and I always wondered how far it would go? So we call a car company to take us to the airport and the driver didn't know we drove one;;;his guage started screaming 10 miles to empty as he left our house 35 miles to the airport; I watched as it went to "O" and than flashed warnings and warnings as he drove 80MPH....just before we got to the airport he said he was "low" on fuel and wondered if we had time to stop; we said ok....so it definitely had at least 3 gallons left when it flashed empty.......would NOT want a luxury car driver to be stranded.....!!I suspect the same with Lexus and others!!
Old 04-23-12, 08:42 PM
  #34
m1964
m1964's Avatar
Exclamation
Originally Posted by smehta
Thanks to everyone for your comments. Point taken - try to fill up around 1/4th tank.
I will try to avoid running the tank down to a low level for the sake of convenience. The comments re fuel pump make good sense.
wife had a habit of bringing the car home w/ low fuel level light ON-we had a volvo XC90 which she parked on our inclined drive way, nose down-next morning XC90 did not start.
it started fine after I put about a gallon of gas I had (stored for the lawn mower)-the lesson is it may not be a big deal to run empry on fuel but may be
1 very inconvinient
2 may cause engine check light requiring trip to the dealer 2 ry to mis-fires
3 may leave you stranded in the middle of nowhere -VERY INCONVINIENT
Old 04-26-12, 10:27 AM
  #35
Konadog
Konadog's Avatar
Very informative. Thank you.
Old 04-26-12, 12:18 PM
  #36
Evitzee
Evitzee's Avatar
I've run the counter down to '0' several times and each time I was able to put 17.2 gallons in the tank, just two gallons short of the stated tank capacity of 19.2 gal. How much of the two gallons is really available for use is unknown, but I don't worry that much when it hits '0', you have a bit of driving left in the tank to get to a station.
Old 05-17-17, 06:31 PM
  #37
kabirahmed
kabirahmed's Avatar
Smile Gas on RX 350 & Hybrid
This is what I found out. please, let me know if this helps to any readers out there. When you see low fuel on year Model 2011 and up on RX 350. Even if its, a Hybrid Model.
U got exactly 42miles before you are completely at Stop. I did a test drive and this is what I got. I was stop on the side while driving on highway. Don't worry I did prepare for 3GL Gas tank with me.
It was a Test drive I did. Hope this helps.
Old 05-17-17, 10:12 PM
  #38
salimshah
salimshah's Avatar
Received 1,050 Likes on 948 Posts
I admire your drive to get the number 42 .. but that can not be applied to all vehicles and even for yours.
Who ever owns the Hybrid ,,, the owner manual states that do not drive till the you run out of gas. [not sure if that statement is to ensure the owners dont count on electric battery/motor to get them further or it sets up a situation that the program controlling the the two power sources can't handle].
Salim
Old 05-19-17, 06:54 AM
  #39
vlad_a
vlad_a's Avatar
Salim
Ditto. Hybrid will do a soft-stop before running completely dry to prevent damaging the system. I learned the hard way in a Prius. And it becomes one heavy car to push once it runs out of juice. Boy, was I mad to find out there were still a couple gallons in reserve when I filled it up.
Old 04-05-22, 08:11 PM
  #40
darklight
4th Gear
darklight's Avatar
Default Gas tank size?
I know in the manuals and on websites they say the 2015 Lexus RX 350 has a 19.2 gallon tank, however tonight I made it to a gas station with 7 miles remaining, according to my dashboard. After fill-up the pump showed a total of 15.6 gallons, which means I'm really working with a 16 gallon capacity. Is there something wrong with my gas tank? Has anyone else tried driving until close to empty and can verify they have a 19.2 gallon tank?
Old 04-05-22, 10:02 PM
  #41
salimshah
salimshah's Avatar
I understand the need to know the exact capacity, but the usable capacity is different. The pickup point is not at the very bottom. The tank has baffles to give it strength and that creates little pools of non-usable gas.
For longevity of fuel pump, it is best to keep it above 1/3 tank.
Salim
Old 04-05-22, 10:45 PM
  #42
ColAngus
ColAngus's Avatar
The car will continue for about an additional 70km after it says "0km distance remaining". It's overly forgiving in that respect and it is 19.2 USgal
NJLEXES (04-06-22)
edupim
RX - 1st Gen (1999-2003)
04-24-14 04:25 PM
dlin95123
ES - 5th Gen (2007-2012)
03-25-13 06:24 AM
cn2004
Hybrid Technology
03-08-13 11:23 AM
markrivers
RX - 3rd Gen (2010-2015)
02-19-12 07:05 AM
ChitChat
27
04-14-10 12:16 PM
Quick Reply: Gas Tank Capacity
