pickup and acceleration
Pls ignore if my post does not make sense and I am just being too worried about this one.
When I got the new RX 2 months back, i noticed how smooth the acceleration was from 0 - 60 with RPM increasing steadily to max 2.
Now, its summer here, and i see the RPM increase to 3.5 at a speed of 40, then drop to 2 and increase again, while the speed increases from 40 to 60. I mean i feel like a jerk at 40 and then it gets the power again.
I think I feel like more jerks when accelerating than earlier.
Is this all just a normal thing or can I have a dealer do any inspection ?
I must admit though that when this happens, I'm not looking at the RPM gauge. I'm just feeling a hesitation after taking off from the light.
The dealer just called to inform that everything is fine with the car. He did tell me in the morning that the car adjusts to the driving patterns and so if there are multiple drivers, you might have a different driving experience.
I will definitely try this one out once I pick up my car in the evening. I am assuming the dealer might have done something like that today :P
I'm the only driver on my car, so there wouldn't be other drivers to adjust the driving patterns, except occasionally when my brother is in town( 3 or 4 times a year) and he drives it occasionally.
Thats one of the problem with most cars today, lagging transmission. In an effort to increase fuel economy, trannys now a days try to hold onto a lower gear for too long. As a result, the car feels sluggish until it shifts into the next gear, then it surges a bit because the rpm shoots up higher than it should. Disconnecting the battery will reset the tranny's adaptive program, but thats only a temp. fix. A sport mode would be nice in the RX or one can try to drive their car more aggressively.
x3;
I haven't felt it on my rx350, but i have felt similar issues on my BMW.
The BMW also adjust according to driving conditions. I disconnected the battery, and felt an immediate change in acceleration. It was much smoother and responsive.
All manuals say to detach the negative(black) terminal first and then the positive. Do I basically have to remove both the terminals and leave it idle for 10 - 15 min ? This is my first car, and am really bad with the basics :P
Since this is a negative ground system car (as most are in North America), I would disconnect the negative terminal. If the cable flops and hits a metal component, it is grounded already. You do not need to disconnect the positive and negative, only one is sufficient.
I did the reset, and I think there might be a slight change in the performance but nothing really significant.
I loved how smoothly my car would go from 0 - 60 in 6-7 sec with a perfect constant acceleration, but now I feel like little hiccups as the rpm switches twice in the interval. Dont know if this is just usual.
Just curious what kind of fuel are you using, like Regular Unleaded, Premium, etc. I know our cars take Premium, but many have gone to lower grade octane without any issues. I understand, going to lower octane gas, reduces the performance.
