Chrome Amber Signal Blubs
Old 07-06-12, 05:10 PM
kitlz
No, I don't play soccer!
kitlz's Avatar
Originally Posted by DMC9114
Thanks Anita! The manual only references WY21W bulb size, but I did read somewhere that this was equivalent to 7440 bulbs; thanks for confirming this. Also, good to know that STEALTH will do a quick compatibility check before processing the order.
The Sylvania website says 7440A for the blinker bulbs. That's a good place to check. Not to add to your confusion, I have Stealth 3457 in the front blinkers and Philips SilverVision WY21W in the back blinkers. They are the same bulb size (WY21W) in the 350, but not in the 450h with LED headlights. I found out the hard way Well, on the bright side (no pun intended) I have replacement bulbs if the rear blinkers go out. So far so good on both sets.
TRACKMKIII
GS - 1st Gen (1993-1997)
05-27-19 06:05 AM
H60Driver
IS F (2008-2014)
07-14-15 12:31 PM
2GSC300
06-13-12 12:38 PM
jonnyxboi
04-06-12 10:17 PM
bigblack06
01-16-12 07:22 PM
Quick Reply: Chrome Amber Signal Blubs
