Dent on right bumper - How much would it cost to fix? (Pic included)
Accidenaly backed into my own car
and made a dent, any idea how much it would cost to fix?
![Name: IMG-20110807-00831.jpg
Size: 127.7 KB](https://www.clublexus.com/forums/attachments/rx-3rd-gen-2010-2015/461536d1501791993-dent-on-right-bumper-how-much-would-it-cost-to-fix-pic-included-img-20110807-00831.jpg)
Bumper is very easy to fix if there isn't any cracks. Take the bumper off the car, apply heat on the under side(heat gun), it will pop back to the normal position. If you are not comfortable with using heat gun, please leave it to the pros. Next to think about is the paint work.
From your picture, can't really tell if there are any damages underneath the bumper.
lucky paint didn't chipped. if you don't have a heat gun [make sure it doesn't get to hot if you are using the heat gun], warm the dented area with hair dryer in "high" until it turns hot/soft [hair dryer doesn't get hot enough to burn] and slowly push it out from shallowest area. no need to take the bumper out/off since you can access the area from under or from side. once its out to its original shape, try to "mold" it where there may be some "hard" area with your thumb. Eventually with more heat after the dent is pulled it will begin to shape on its own as it cools down. It is really easier than sound so try it.
honest body shop will repair using the method above and probably not charge you anything but most likely will try to repair using the refinish method. This means painting and color will no longer be same shade and repair will be noticeable.
You should have gotten under the car and pushed it out asap after it happened. After doing that, place the car in the hot sun. It would have disappeared. You can still do this, the auto body shop will use a heat lamp on it.
Regards, kona44
