Weathertech Side Window Deflectors
#31
No, I don't play soccer!
I had the WeatherTech visors on the previous RXs. Installation can be scary. They need to be bent to get in the window channels. Afterwards, WeatherTech advises leaving the windows up for a few hours to set them in place. They needed an occasional gentle push up at times because they moved. Not often though. Only one broke after a few years. It may have been my fault. I probably pushed the wash mitt underneath the rear visor too hard to clean underneath.
I would have gotten them for the 450h but the rears were not available back then. So I went with the JDM visors instead. Couldn't be happier.
Leddy (04-04-17)
#32
https://www.clublexus.com/forums/rx-...rs-w-pics.html
Here is a link that may be helpful. The install on WeatherTechs seem scary, but it's nothing to worry about. The material they use is good quality. The only down fall I’ve seen was that the rear deflectors tend to loosen up at times. The JDM visors are the way to go, but everyone knows how expensive they are.
#33
#38
I have problems with WeatherTech's rear windows visor too.
I ordered the whole set (front & rear).
When it came, only the 2 shorter side of the rear piece had double-sided tape on, none is on the longest side, the package came with the clipper that it cannot fit on a RX; and without a doubt, the tapes on the 2 shorter side couldn't hold the visor in place (after leaving the windows closed for 72 hours)
I called weather tech to order some more tapes (no charge). Went back and taped all 3 sides of the rear visor/deflector with the auto-grade double sided tape they sent me, set for 24 hours before putting on the rear windows channel, let it set for another 72 hours...low and behold, the pieces still fall, not right away when I opened the windows, but a little tap on the deflector did it.
As last attempt.
I bought the 3M auto grade double side foam tape; I will try to use this on the longest side of the rear deflector to see if it does the trick to hold the rear piece in place firmly without falling
http://www.amazon.com/3M-03614-Scotc.../dp/B002JOVUO0
I haven't gotten a chance to try it on yet, and I don't know if the foam tapes' thickness will cause problem closing the window.
I hope that the 3M foam tape will do the trick to hold the rear pieces up securely.
Side Note: I used Weather Tech windows deflector on my toyota also, the rear pieces held up securely, perhaps it's the design of the Rx's windows channel.
As last attempt.
#39
CodeRed, I hope your fix works. Weathertech had issues with the rear deflectors when they first came out as previously mentioned. Strangely enough no problems on previous RXs. They had single strips of tape on all sides. Guess that isn't possible on the 3RX since it has a strange angle.
#40
Weathertech included small metal tool to help with clip installation.
#41
I still haven't gotten a chance to prepare the rear piece with foam tape yet, I will post the end result here if it works.
#42
It does come with the metal piece but I misplaced it along with the metal clips in the plastic bag (Doh!!)
The diagrams show the clips being installed on a small sedan-like vehicle with exposed rubbers that you can pull down and slide the clips in-between, I don't find it on the 2013 RX and the way it is designed, it didn't seem like I can install the clips the way it is shown in the diagrams.
I did try to push the metal clips into the channel though; but I didn't wanna break anything and also worried that the clip may cause scratches/cuts on the glass, so I didn't try to push it in hard.
- I didn't use the metal clips partly because I also had WeatherTech on my 4Runner; the package also came with the metal clips but I didn't have to use them (and the rear deflectors have tapes on all 3 sides), 3 years later and they are still securely in place.
I'd appreciate the pictures, so that I can try again before going for the 3M foam tape option.
#43
I will try again tomorrow, that time will be outside. It's difficult to take a half decent picture of those clips (2 per each rear deflector). They are small and are deep in the rubber window channel. Dark deflector blocks most of the light there.
#44
I tried taking pictures in the garage, but it didn't work - too dark even with the flash.
I look forward to seeing those pictures, my ride looks like a handicap in my eyes (somehow) with only the front deflectors
#45
Got a few pictures. Couldn't take a picture at even closer distance because the deflector is in a way, and everything getting very blurry (just like or even worse than the 3rd shot). I'm a lousy photographer - sorry.
