how often to nav maps come out
Registered User
I am waiting for the next update as several roads have changed or been added around me since I bought the RX. 10.1 will not have the most recent changes, I believe it is a year old. I do feel $200 is a bit much $100 would be better.
$300[200map+100labor] was what it cost from v8 to v9 from the dealer. it required firmware update so it took few hours. v10 only had few updates so I skipped but I am looking forward to v11 [sometime in November] and hope Lexus have newer routing calculation method on v11 because sometimes its really strange how it calcuates the route in the city.
The thumb drive does not contain the map data. You can't just plug it into you usb and expect it to update. It contains a data key that allows the Techstream laptop to update your hard drive with the map data.
Registered User
For example. If you choose the shortest route. It will take you off the highway. Go on to a side street then back on to the next highway. To save about a 1/4 mile not going through the long interchange.
Another is going around private roads.
lexuslover
03-30-03 07:55 AM
