Navigation Unlock
Navigation Unlock
In reading some old posts I noticed a few of the mods had "coastal lockpick" on thier vehicle specs. I was not sure what that was so I googled it and, well, I think that is a great product. I went to their website and it does not mention anything after 2009 for Lexus and Toyota. What it does is unlocks the NAV so your passenger can input stuff on the move, opens up DVD player options etc.
I have emailed them about never vehicles but have not heard back yet. Does anyone know of a similar product? Anyone using somthing like this?
Check VAIS their SoundLinq2 does unlocking of the nav and bluetooth but you will have to check the compatibility for your car www.vaistech.com
We also carry a bypass for Navigation and DVD as well. You may check it out at: http://www.beatsonicusa.com/beat-son...ss-module.html
Please let me know if you have any questions.
It's about a 45min to 1 hour to install. You need to get behind the radio/nav unit. Not difficult as long as you take your time.
Forum Administrator
I've got the Lockpick on my LS; after you upgrade to a newer version of navigation software (after 5.1) it isn't useful for the override as Lexus removed access to that feature in the software.
I sent an email to Prestige and was happy to learn that you no longer have an on off switch. It is activated by the volume button on the steering wheel.
"Our latest system no longer has a separate switch. The system is activate/deactivate through the factory volume controls on the steering wheel while maintaining your factory volume functionality."
You can turn it off the same way to gain access back to the NAV after you set your destination etc. If you forget it will reset itself when you turn off the car.
This in my mind makes it a very attractive solution as there are no extra wires to run or switches to use.
It activates via the volume switch. Once activated it allows you to program the NAV system or watch dvd on nav screen. You would want to disengage it once you have set the NAV as until you do the nav is offline. Once you disconect it the NAV jumps back to real time functions.
If you forget to turn it off, it automatically resets when the car is restarted so you dont have to worry about that. It seems like a very good system. It works by fooling the car into thinking that it is stopped so the functions that are locked out my motion are accessible.
Jerryray, you have one of the older ones it seems, how do you like it? Good quality? Any issues? Install easy?
lexgolf
04-13-14 10:18 PM
sleepybobcat
04-17-01 06:04 AM
