Faint Beeping When Driving
Old 11-04-11, 07:25 PM
MX5NES350
MX5NES350's Avatar
Originally Posted by Cruiter
That's the 1st I ever heard of it. To my knowledge there is nothing in the manual about that.
Best bet is going to be a consult with the Service Dept. There's stuff on these things the manual doesn't cover b/c us owners don't need to know that there "techy stuff" Afterall if we knew ALL the secrets how would they make money
Old 11-07-11, 04:23 AM
MX5NES350
MX5NES350's Avatar
Ever find out what it is/was?
Old 11-07-11, 09:17 AM
RXSF
RXSF's Avatar
Nope. I have a 10K service coming up in a month and I guess I should bring it up. It happens sporadically so that I dont even know they can help me or not. Tire pressure seems normal.
Old 11-07-11, 10:07 AM
MX5NES350
MX5NES350's Avatar
More than likely they will take it out for multiple test drives and the sound won't show up. As soon as you drive it off the lot, however, it will return. I think that's the way these thing normally unfold.
Old 11-07-11, 10:12 AM
RXSF
RXSF's Avatar
lol yeah that sounds about right. luckily I have a good SA. The problem doesnt bother me in the sense that the noise is annoying. I am just curious what it is!
Old 11-09-11, 02:50 PM
markrivers
markrivers's Avatar
Is the brake pedal depressed when you hear the beep? The wife might be pressing on the pedal too hard, which activates the TRAC.
Old 11-09-11, 03:55 PM
RXSF
RXSF's Avatar
no its definately not as loud as that kind of beep. Its very very feint. You could almost miss if if you arent paying attention
Old 07-07-15, 02:38 PM
dmac1953
dmac1953's Avatar
Default faint beep
My 2008 RX350 also has the faint beep somewhere under the dash. No warning indicators, not low tire pressure, doesn't make any difference to the type of driving I am doing. Doesn't happen just because I have washed the car, just driving down the freeway and beep. It seems it only does it once per driving session, at random intervals meaning it may be 5 minutes after I start the drive, it may be 10. It is more of a curiosity than a problem.
Old 07-08-15, 07:37 AM
raylor4
raylor4's Avatar
Just a wild guess, but do you have a battery-powered device somewhere in the car with possibly a low battery. I have devices that emit a faint beep when the battery is low.
Ray A.
Old 07-08-15, 08:23 AM
kitlz
No, I don't play soccer!
kitlz's Avatar
Great suggestion, Ray. Remember the posts about the mystery beeping noise in the garage? It turned out to be the garage opener.
dmac1953, welcome to CL. I'd suggest you do a search over in the 2RX forum as well. I don't recall a thread that might explain the mysterious beeping. Good luck.
Old 07-08-15, 11:07 AM
tigerdan
tigerdan's Avatar
What was the resolution of the problem with "RXSF " , the post was over 3 years?
Just curious.
Old 12-12-17, 08:59 PM
CS4E
CS4E's Avatar
Default Help
Hi there,
I have the same issue. It just happened earlier today. Can you tell me what you found out after you took the car in? Thanks!!
Old 12-12-17, 09:49 PM
salimshah
salimshah's Avatar
Received 1,098 Likes on 988 Posts
If the sound is in the garage, check the water softener [if you have one]. Low salt level sets out a faint beep.
Salim
Old 06-15-19, 03:10 PM
GTheriot
GTheriot's Avatar
Default Fixed ( I Think)
Originally Posted by CS4E
Hi there,
So I was experiencing the same faint steady beep sound and it turned out my golf clubs got jostled around and hit the button that raises/lowers my third row seating. Maybe check to see in the back seats are all the way up or down.
Old 09-05-22, 10:22 PM
A2005LS430
A2005LS430's Avatar
I actually am having this problem with my 05 ls430. The beep sounds like when the car senses a nearby object, it is that same sound but a quick beep and happens every 45 seconds or so, and only beeps when I’m driving with the stereo on. Weird…
I was thinking it was a tire sensor, so I checked all 4 tire’s PSI and they were at 34psi with I think Zrated tires…I put ‘em up to 38psi and I still have the sound..maybe I need to raise psi even more..
Originally Posted by MX5NES350
Silly question but have you checked your tire pressure lately? Some vehicles (not sure about the RX) have a sensor that will go off if your pressure is a hair too low (but not low enough for your TPS to catch it). I usually will be set off by the vehicle entering a turn or otherwise having swaying movement.
rjk
Hybrid Technology
04-14-17 07:12 AM
USCRugby
02-17-08 05:53 AM
Jakex1
11-30-07 10:56 AM
A.C Milan
09-29-07 05:28 PM
y2ks2k
04-23-07 07:56 AM
Quick Reply: Faint Beeping When Driving
