Bluetooth Issues
My 2010 RX350 bluetooth system seems to have a mind of its own. It frequently disconnects and will not reconnect for days.
Any suggestions?
Thanks
Any suggestions?
Thanks
Are you trying to connect your phone or music? I had a problem connecting to my old Pantech phone. The dealer and I tried everything. It would connect once and only once a day. I had to get a new phone even though the Pantech met the required bluetooth version. I got a Samsung and it works perfect for both phone and music.
I am observing a similar problem with my new iphone 4s. Not reproducible always, but many a times it disconnects after I change the mode (bluetooth to fm/am/usb). I am then not able to reconnect it until i turn off my car.
Could it be an issue with ios 5 ?
It seems that most of the posts with consistent problems are around folks with the new iPhone. So if that's the case, it's not the car. Maybe the iPhone will have an upgrade in the future that will help. My Samsung droid just got it's third OS (gingerbread) since a year ago last August. Gotta reset something every time too.
I was at the Lexus dealer yesterday and mentioned my problem of the bluetooth dropping connection.
They said they are having a few experiences with this with the Iphone and Verizon service.
The solution is to go into the phone and turn off the blue tooth connection for a minute and turn it back on and connect phone.
Problem solved
Problem solved
Problem solved
Problem solved
I just got an LG Optimus T and it does the same thing too. The connection get drop sometimes, and a few times it can't connect. Once it can't connect when the car start, it will fail to connect even in the car "select phone to connect".
I have not try to turn off bluetooth on my phone and turn back on, but I want a permanent solution. The old iPhone 3GS seem to work fine.
Background: My car is a GS430 '06.
I have no problem with connecting the iPhone 4s via Bluetooth for phone calls but I can never get the RX Bluetooth audio connect to successfully connect to the iPhone 4s for streaming music. Has anyone been able to successfully perform Bluetooth audio connect with iPhone 4s??
