Fuel consumption gauge
On my fuel consumtion guage on the Nav system, I have a pretty bar graph but all the dates at the bottom are empty. In the calendar funtion it is showing the correct today. I have actually read the manual and i can not figure out if there is a setting to input this information.
Suggestions anyone?
Suggestions anyone?
Have you reset the graph since you got the car? Don't push the clear button on the nav display if you wish to keep a lifetime average.
Reset your average mph or kph and mpg or l/100k from the steering wheel. That resets the graph. I reset it with each tank of gas. Other folks reset it on other intervals, such as at the start of a trip and at the end. That info is in the multi-informational display. At least on the US version, not sure of Canadian.
I have reset it when I put in my second tank of gas. It still did not add any dates to the graph. I will ask when I take in for my 1600km service unless someone else has an idea.
I have almost the same problem. My graph shows minutes and when I cleared everything out, hoping to reset, it still only shows "Today" and no other dates. I've gone thru the manual with a fine tooth comb and have found nothing.
