RX350 Cabin Air Filter
#46
Sevn, I think you will like this. I read in this or some other thread about a secret
hidden storage and it is nice... I just threw the manuals there. When you lift your center console hand rest,, you can lift up the storage box and underneath it, you have more room plus area under the cup holders where you can happily store those manuals....Credit goes to kitlz or whoever mentioned this. I am sure there are folks who didn't realize this...
#47
#48
I just got the Wix bioshield 75 filter. I pulled out the original filter from the vehicle and saw that it is a Carbon impregnated filter. Probably that's what Sewell has for $43. After a little research, I see that carbon helps prevent odors, exhaust fumes, mold, moisture and allergens. I did see a bunch of leaves in. So I cleaned it pretty good and put it back for time being. I have about 1yr/9K miles. Just logged into mylexus and see that Filter is only cleaned at 15K/18mo and replaced at 30K/3yr. Any comments.
#49
#50
I followed the instructions with no trouble except for a minor detail: The original 2010 Lexus Filter was marked with an "Arrow" and its label was "UP" (the arrow pointed toward the top of the housing originally). However, the Purolator C35667 cabin filter I used ( it fit fine) has a printed arrow and a label of "Air Flow" as its marking. Given that the debris on the old filter was on the top of the removed fileter (as it was pulled out) I assumed the Air Flow is from Top to Bottom - hence the new Filer would be installed with the Arrow DOWN, to match the airflow in the housing. Aside from being confusing, does anyone see a problem with this?
#51
I followed the various instructions in the forum with no trouble except for a minor detail: The original 2010 Lexus Filter was marked with an "Arrow" and its label was "UP" (the arrow pointed toward the top of the housing originally). However, the Purolator C35667 cabin filter I used ( it fit fine) has a printed arrow and a label of "Air Flow" as its marking. Given that the debris on the old filter was on the top of the removed filter (as it was pulled out), I assumed the Air Flow is from Top to Bottom - hence the new Filter would be installed with the Arrow DOWN, to match the airflow in the housing. Aside from being confusing, does anyone see a problem with this?
#53
"I assumed the Air Flow is from Top to Bottom - hence the new Filter would be installed with the Arrow DOWN, to match the airflow in the housing. Aside from being confusing, does anyone see a problem with this? "
Makes sense to me. I can't see why it would matter which way it draws the air across it anyway.Just so you always put it back in the same position.
#54
Can anyone confirm there is no housing case for the cabin air filter for 2010/2011 RX350?
The owner manual states there is one, but I didn't see it when I checked my cabin filter yesterday.
#55
I don't recall any mention of a "housing case" in the manual for my 2010 RX350, and all I had to do to replace the CAF was to remove the shelf, set the Recirculate/Fresh properly, and remove the filter's cover, which snaps in over the end of the filter "slot", then pull out the old, and put in the new.
#56
I must have mis-read the RX350 manual. For the RX350, the filter case implies the filter itself.
Thanks.
Btw, the air flow direction is from top to bottom. So any filter with an arrow and Air Flow printed, the arrow should point down.
#59
#60
If I were you I would check out E-Bay. I have seen this filter priced as low as 6.50 each with shipping included.
