RX350 Cabin Air Filter
Old 03-07-11, 01:18 PM
gladiator9
gladiator9's Avatar
Default Installing cabin air filter in 2010-2011 RX350
It seems that any earlier posts on this topic referred to 2nd generatio RX models. I read them which indicated pins that must be turned to remove the glove box. This is not the case with the 10-11 rx. It is real easy to do. Just remove the small shelf in the glove box.....pulls upward and snaps loose.
Then you will see an access panel which can be lifted up and removed to expose the filter access. Squeeze the 2 tabs.....1 on each side of the access cover and then pull out the dirty filter. I replaced the original Toyota filter with a fram filter from Walmart. I also changed the engine air filter and it was a breeze to do. I ordered a fram filter from Autozone......cost about $21.00. It took no longer than 15 min to do.
Jim
Old 03-10-11, 09:52 AM
gladiator9
gladiator9's Avatar
Doesn't the air rec button just recirculate the cabin air as opposed to fresh air from the outside?? I will set this on recirculate only if we arepassing by a feed lot or an area that smells terrible. Hope the filter catches all the dust from the Arizona air?
Cheers,
Jim
Old 03-10-11, 10:00 AM
Barrington
Barrington's Avatar
I only use the recirc when I have the A/C on or like you said if driving in a real dusty or smelly area.
Old 12-13-11, 01:14 PM
GoHuskers
GoHuskers's Avatar
Default RX350 Cabin Air Filter
Can any one show me how to replace the Cabin Air Filter in 2010 RX350?
I read in here that you need to switch to the ReCirc mode but then how to remove the shelves in the glove compartment? I almost broke it another the day but still can't take it apart.
Please help. Thanks.
Old 12-13-11, 02:31 PM
MX5NES350
MX5NES350's Avatar
Instructions: http://lexus.sewellparts.com/pdf/ac_filter-2.pdf
Sewell is your friend.
Eric
Old 12-13-11, 02:43 PM
InRBigness
InRBigness's Avatar
shelf comes out. pull firmly.
Old 12-13-11, 04:17 PM
kitlz
No, I don't play soccer!
kitlz's Avatar
I can't remember the trick to remove the shelf. I believe you have to move it backwards while angling the back up. I keep mine somewhat unsecured for easy access. For the cover behind the shelf, push it up until there is a gap on the bottom, then flip out the right side. The dealer has probably replaced the cabin filter already so it's a little easier to remove. Good luck.
Old 12-13-11, 04:21 PM
InRBigness
InRBigness's Avatar
Speaking of the shelf, is there a bettter place to put the manual in the car? Mine plus the Nav system book takes up the whole damn glovebox and even then it doesnt fit. I read that some of the other Lexus's have a place in the back for it. Seriously you look at it every 12 months but I still want it close incase I do have a question.
Old 12-13-11, 04:28 PM
MX5NES350
MX5NES350's Avatar
Stick some male velcro on it and hang it with the first aid kit or adhere it to the rear cargo mat or I think there is a place beside the spare tire it can fit. Maybe toss it in the cargo net? I dunno. I'm frustrated with how big it is as well. I figure if I can operate the vehicle I can just store the manual(s) in the garage until I get home. It's like having a copy of the Gutenberg Bible in my glove box. You would think they would have downloaded all of this to retrieve through the nav system by now.
Old 12-13-11, 04:32 PM
kitlz
kitlz's Avatar
Jairus, I guess you haven't checked the black hole called the middle console. There is supposed to be an area especially made to put the manual in there. I think the area goes underneath the cup holder to the side of the outlets. Needless to say I don't use it.
Old 12-13-11, 04:52 PM
InRBigness
InRBigness's Avatar
I agree completely. The thing should have come with wheels and a carry on pull handle. I think I will just put it in my office as it takes up rediculously too much space. If you look the thing does not even fit in the glove box. When you shut it it tilts on an angle. My Nav book has bent edges already from that.
Old 12-13-11, 05:38 PM
GRPFAN
GRPFAN's Avatar
Or you can burn everything, and check here for the answers................
Old 12-13-11, 06:13 PM
kitlz
kitlz's Avatar
Another alternative is to put the tow hitch to good use and haul the manual
Old 12-14-11, 05:00 AM
MX5NES350
MX5NES350's Avatar
I thought that was what the cross bars were for?
Old 12-14-11, 06:20 AM
GoHuskers
GoHuskers's Avatar
Eric
I got that sheet but it is NOT for the 3RX series.
So, the shelves must come out first by pulling TOWARD you and UP? Then push the cover UP and to the RIGHT?
I will try again. Thanks everyone.
Quick Reply: RX350 Cabin Air Filter
