Headlight difference
#46
Sorry to revive and old thread but I’m shopping for a used RX of this generation. I need to have hid lighting, I can’t deal with halogen bulbs anymore. On the 2010 face it’s easy to tell which ones have hids and it’s bundled with the gps package as well. I found a 2014 I like that doesn’t have gps but it has projectors in the headlight. I can’t tell for 2014 did they make hids standard or is it simply a halogen projector in there. Thanks guys!
#47
Halogen projector was standard.
Enter the VIN here https://drivers.lexus.com/lexusdrive.../vehicle-specs
This will specifically tell you if the vehicle was equipped with HIDs from the factory.
#49
#51
No. That is a Scion xB, HID was not offered from the factory. It is halogen projector low beam and halogen reflector high beam.
#53
Ok. Well now you've heard of it.
#54
From HID Planet
“halogen projectors usually dont have alot of r&d into them, since it doesnt matter. There is not enough light to really warrant the need for excessive optic positioning or lens distances. With hid projector, there is alot more light that needs to be spread evenly. Hid projectors are designed specifically for hid bulbs.”
Basically Toyota/Lexus use both halogen and HID projectors. From the outside all you see is the shroud and the lens which look identical hid or halogen. Where the big difference lies is in the reflector. You can put a hid bulb in a halogen projector but the light will just go everywhere and blind everyone on the road.
Marn1
03-22-19 10:16 AM
chrispy
04-28-08 01:36 PM
