2011 RX350 Antenna Fin fell off
Old 01-21-12, 08:27 PM
McDMan
McDMan's Avatar
Unhappy 2011 RX350 Antenna Fin fell off
Hello!
My garage door malfunctioned and cam down hard as I was driving into my garage. Fortunately, my side rails took most of the brunt but it tore off my Antenna Fin. Luckily, it came off in one piece and I can glue it back on. But can someone please help with 2 questions:
1) It does not look like there was any electronics (wire?) actually enclosed in the fin except for some enclosure housing an electronics 'chip'. In other words, nothing really jetted up into the fin. Could something else have fallen/broken off?
2) There is a black piece of rubber that separates the fin from the car roof. It looks like there is a 1mm space between rubber and the roof (at the back of the fin). Do I have to worry about water leaking into this space and entering the car? Or is this 1mm space normal?
Any help is appreciated.
Thanks, Charles
Old 01-21-12, 09:04 PM
happy1977
happy1977's Avatar
I'd take it to the dealer if unsure of how things are suppose to be.
Old 01-21-12, 09:40 PM
InRBigness
InRBigness's Avatar
Are you saying there is no wire running through the roof into the shark fin? It is my understanding that there should be a wire that runs through the base into the sharkfin and that the fin basicly covers up an antenna that is under the shell.
You best get it fixed soon as that is the stabilizing mechanism that makes the RX so solid on the highway. The areodynamics will be thrown for a loop with out it.
Old 01-21-12, 10:25 PM
RXSF
RXSF's Avatar
^^ hehe
You definitely need to replace the rubber seal with a new one so that it affixes properly and is sealed tight from water. I am unsure if there is supposed to be a wire either
Old 01-22-12, 08:07 AM
MEP7557
MEP7557's Avatar
I looked at the parts online and it looks like there is a connection to the antenna, a plug in. Not sure if that applies without the nav system. The antenna, shark fin, sells for $165 w nav. I did not see the seal listed separately but the dealer might have better access to parts.
shadowmite
RX - 4th Gen (2016-2022)
39
06-20-19 03:42 PM
gompka
NX - 1st Gen (2015-2021)
04-13-18 03:14 PM
mRak
05-24-11 10:08 PM
AKAlius
03-05-11 05:39 PM
Quick Reply: 2011 RX350 Antenna Fin fell off
