Possible to disable door chime?
On a 2011 RX450h, is it possible to disable the door chime when the drivers door is opened but the car is in accessory mode (i.e. not running)?
Since I just got the RX I've been playing a lot with the settings and audio presets. With the drivers door open the chime just continues forever and I cannot find any option to turn off the chime when in accessory mode.
Thanks all!
Thanks all!
You might not want to disable the chime on a 450h. Since the vehicle can be ON, but appear to be OFF, sooner or later you will find the chime a useful reminder about vehicle status. Plus there are times when you absolutely need to hear the chime ... like when your key is in the car and it will not lock.
Thanks all!
Thanks all!
I hope this helps you out.
Patrick
![](http://mefi.us/images/fuelly/sig-us/110013.png)
View this entire album and more pictures: ClubLexus
![](http://just.razzi.me/photos/435966/9394957.jpg)
![](http://just.razzi.me/photos/435967/716460a.jpg)
![](http://just.razzi.me/photos/435968/1527f0c.jpg)
![](http://just.razzi.me/photos/435969/5d5e7ab.jpg)
![](http://just.razzi.me/photos/435970/d5c2379.jpg)
![](http://just.razzi.me/photos/435971/680a567.jpg)
![](http://just.razzi.me/photos/435972/fd4a5e6.jpg)
I just went into the garage and sat in the front seat of 'Watson'. I looked around at everything all nice in it's place and said "self, it's all fine and doesn't need to come out for anything" .
Being an old (emphasis on old) Navy Photog, I've gone into cameras back in the day and managed to get 'most' parts back in and they'd still work but after seeing your dash, I have to give credit where it's due, I could never even want to attempt that. But seems like you did it w/o a problem just to fix a chime. KUDOS![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
. Either way, it is simple to find once you finally make it through the fine engineering the holds everything in place rattle free. Here are a few pictures in case you were curious.
Patrick
Patrick
![Post](https://www.clublexus.com/forums/images/icons/icon1.gif)
Thanks all!
Thanks all!
I have the same issue with my RX450h. I actually have it at the dealer today to hopefully get it fixed. They say that there is something in the steering column that is causing the chime to be on. Some sort of issue preventing it from being in "normal" mode. I will report back if they actually fix but I have my doubts if they can even find it and I'm only allowing them a few hours to look before they want to charge me more for diagnostics.
Sadly, I did not get it fixed. The Dealership said it was something in the steering column that needed to be replaced and was going to cost $1400. I'm going to try to find where that damn chime is and take it out. I have looked but I'm not sure where it is and even though I can hear it under the dash it's hard to locate. I would love to hear if someone else has found a way to silence this because I know others have encountered it. I'd rather not disable the door switch but that would be a lot easier.
