Nitrogen and Valve Stems
Old 03-15-12, 01:28 PM
LexBob2
LexBob2's Avatar
Originally Posted by UCSB
I thought my 450h was delivered with nitrogen, but there is no indication of this on the valve stems or caps. So now I just don't know the status. One nice thing on the 450h is that it shows the tire pressure in each tire in the information display area. That addresses many of the arguments for using nitrogen because you know your actual tire pressures.
I only learned of nitrogen in my tires when I was looking at the PDI and service history online. It showed the PDI and included was Nitrogen Fill on the online checklist. Maybe there is something like that on yours?
Old 03-15-12, 07:15 PM
MEP7557
MEP7557's Avatar
My RX came filled with the nitrogen and there was no charge for it. I also do not have any identifying markers on the valve stems, thankfully. I never have to adjust the pressure between hot and cold weather like I have with other vehicles, that is one of the benefits. My Dealer will check pressure for free and will use nitrogen if the tire needs air.
Old 03-16-12, 07:19 PM
LeoDLion
LeoDLion's Avatar
A tank of liquid nitrogen cost about $500 per 25 lbs. Very expensive stuff. And you need a delivery system to stick it in the car. The cost of $50 for four tires is probably reasonable for a Lexus.
The RX is delivered with N2 in the tires. I don't believe it is worth the expense of keeping it in N2. I never find any rust in my wheels ever in all the cars I had. Air permeating out of the rubber? Just check tire pressure once a month.
Old 03-16-12, 07:31 PM
GRPFAN
GRPFAN's Avatar
On my 2000 RX 300, I had a terrible time keeping air in all four tires because the aluminum rims
were oxidizing causing the tire bead to lose 15-20 psi of air a month.
I paid $50.00 each tire for them to break the bead and smooth the rims out and add sealant around the rim.
Guess What? It didn't do any good, those tires still lost air................
BTW........ aluminum rims don't rust
Old 03-17-12, 08:35 AM
cafpaf
cafpaf's Avatar
LeoDLion, We are talking about nitrogen gas here not liquid nitrogen. Liquid nitrogen would freeze the rubber and it would break apart like glass. Nitrogen gas is applies in exactly the same manner regular air.
Old 03-17-12, 10:38 AM
DunWkg
DunWkg's Avatar
50 bucks didn't seem high to me, if the tires are properly purged. Creating a vacuum is not recommended by tire manufacturers. However this writer thinks even 30 bucks is too much.
http://www.popularmechanics.com/cars...stions/4302788
Old 03-17-12, 11:35 AM
LeoDLion
LeoDLion's Avatar
I stand corrected. I am use to dealing with liquid nitrogen. But the point is that the initial investment for a shop to be able to use nitrogen for tires are quite high. And so the fee of $50 is not all that high considering that. Even though N2 is free from the air, there is the N2 generator like the one attached. Not cheap. But as I mentioned I don't think it does that much good.
Old 03-18-12, 08:11 AM
dctex99
dctex99's Avatar
Default Yes, Nitrogen is dirt cheap
In refrigeration they banned the use of R-12 to "blow out dirty condensors" because it harms the air. We now sell them nitrogen in a larger cylinder for about $20....it would fill 500 tires; Nitrogen is the highest profit item you will ever buy!! Costco started this Scam charging $20 to put in 10 cents worth of Nitrogen and than put on green valve caps! We laugh about it where we work as the caps cost more than the nitrogen and Costco , like Lexus, does NOT make sure all air is removed from the tire before then put in the nitrogen. Not even SEARS many trucks put nitrogen in unless they have a tire going flat!!! It is a nice safety backup for low tires on Appliance Service vehicles!!
Old 03-18-12, 08:57 AM
GRPFAN
GRPFAN's Avatar
Does anyone know if nitrogen can be purchased in small container like propane to use
for adding it to our tires???
Old 03-18-12, 09:11 AM
dctex99
dctex99's Avatar
Default No
NO, it cannot; Nitrogen is in a cylinder under VERY high pressure, so has a regulator on it; we sell the smallest cylinder available!! That is also why you can carry in two hands a cylinder that has enough Nitrogen for 500 tires!!! What I DON"T know is how Shell "Nitrogen infused" gasoline is formulated???
Old 03-18-12, 09:17 AM
GRPFAN
GRPFAN's Avatar
Thanks, was just curious
Old 03-19-12, 10:59 AM
billy44bo
billy44bo's Avatar
Took my car in for the 15K tire rotation and the Toyota dealer change over the tires from air to Nitrogen for free.
Less than $24 for the tire rotations and the rest of the checks for the 15k service.
Old 03-19-12, 12:21 PM
GRPFAN
GRPFAN's Avatar
Now that's a steal.
I think that's a good price.
Old 03-19-12, 01:31 PM
LeoDLion
LeoDLion's Avatar
How much would the smallest N2 tank cost including the regulator, delivery hose and other attachments needed to fill a tire with it?
I googled and found this N2 system for some $180.
Old 03-19-12, 05:00 PM
dctex99
dctex99's Avatar
Default Yesss
Yes,, that is the small tank that everyone in the Refrigeration field uses and includes the regulator; it is much more efficient than buying those machines that someone else pictured. Sadly, many auto companies bought those overpriced machines! You can use a device like this to blow out anything as a compressor would and it is very portable!! When it gets empty you just take it in and exchange for another refilled tank and screw your regulatoroo and hose on to it!!
monet33
06-23-15 03:15 PM
USCRugby
10-18-08 05:23 PM
YWW
Wheels, Tires & Brakes Forum
12-09-07 12:34 PM
Quick Reply: Nitrogen and Valve Stems
