is there a way to...
have Climate Control settings be displayed at all times on top of the NAV screen? Like when you change settings, for a short period of time the settings will be displayed above the map...I like to have it visible at all times (if possible)
Thanx a lot
Thanx a lot
You can go into your settings in the Nav screen and find several features that are owner changeable. That's one of them. Then it will stay on what ever screen you last set it to.
Your manual has a whole section devoted to that. It's good reading when going to bed, helps to sleep
Sorry, I misunderstood. Doing it the way you're speaking of is not available. I guess they thought other displays that change such as the map, energy display, music, etc were more important than a static one you can bring up easily enough by adjusting the temp on one side or the other.
Also, when in "Auto" mode, does climate control chages air flow/vents or not?
In amy former LR when set to "auto", the vehicle would adjust temperature, and also direct the air flow as needed: if starting from cold, (after engine warmed up) at first, warm air flow was directed to the floor/feet, and then as the vehicle warms up, the air flow would change to the dash vents w/ cooler air. If starting from hot temp in the summer, cold air woud be directed to dash vents, and not to the floor.
In RX, it appears that when set to "auto", the air flow is to floor ands dash vents, no matter cold or warm air is required.
I don't like cold air blowing to my feet, and warm air to my face (I fall asleep..)
SO far that is the only thing I do not like in RX, everything else is superb!
Remind you that with 400h, there was the ML which was fitted with a narrow display unit where we could see tracks, radio wave, and air conditioned parameters /settings while the nab displayed navigation routes or power generation, etc.
This is lot possible with the 450h (the RX gen III basically) and I find this new way a step backward as we have to change screen to get other information... which is potentially hazardous and unsafe while driving.
Any reaction?
I agree with the posters that would like to see audio information (eg Artist and Song Title) while in normal Nav mode. I've seen Nav/audio systems on other vehicles that do this and I am disappointed that Lexus doesn't provide this function. Wonder if Lexus reviews these posts and considers them when its time for product updates. Lexus...if you are listening...this would be a nice feature.
