A piece I do not know it comes from!
Hi All,
I 've gotten my car last Friday after the 45'000km service including a total cleaning of the leather seats and exterior cleaning and polishing.
Last Sunday (yesterday) I drove the car for about 450kms without any problem but a real pleasure as usual.
After a car wash today when wiping the car and particularly wiping of the right side-view mirror I have discovered this little metal piece (see pics attached).
The piece was found almost like this (after I've pulled it a little bit with my nail)
Another view
and anoother one
Do you know this?
It was found behind the mirror of the side not fixed.
I removed it carefully and my mirror works perfectly, no noise, lights, etc.
I will send the pics to the Lexus car dealer tomorrow and will ask for explanations.
In addition, to this I've noticed that my removable trailer ball (which was placed in the trunk against the spare wheel below the plate covering spare wheel) was not in the trunk anymore certainly because they have removed it for accessing some areas and forgot to replace it.
Another view
and anoother one
Do you know this?
No, I don't play soccer!
I think that might be one side of the clips that holds the mirror in place. There were four pieces that looked like that if I remember correctly, two side by side on either side of the mirror. You might try carefully moving the mirror from different angles with your fingers to see if it's loose. Or remove the mirror completely by tilting the mirror up so you can put your fingers under the bottom and then pulling it out. Unfortunately I don't have a picture of the back of the mirror to explain it better. I'd bring it to the dealer to check. Maybe someone knocked into the mirror strong enough to break it during the exterior cleaning.
Pop off the mirror and reinstall it. If I remember properly it is a guide for the sensor to tell where the mirror is in its shell.
To get the mirror off, put your fingers around the out side edges and gently pull the mirror out. It sits on 4 plastic rods with ***** on the end that go in the holes in the white disc on the picture above. While your at it, change out the bulb to an LED
Hi All !
... and many thanks for this input and it is the small piece I have pictured above... apparently you know this better than the car dealer I called on Tuesday a.m. because he told me that he did not know from where that small metal part comes from (unbelievable!)
Thanks I do will try to remove the mirror as you indicated and will keep you informed (with pics to feed the forum with info)... unless I have the chance to visit the car dealer but little chance (70kms away from home).
It really is not that bad. I changed my puddle light bulbs to LED ones (you should make use of this time to do yours) while in the parking lot of a hockey rink in the middle of November at just above freezing. I had to remove both mirrors and undo 4 screws on each one and install bulbs and it took me just under 15 minutes to do both with no bad repurcussions. It is psycologically stressing the first time you pull out the mirror but if you spread out your fingers on the outside edges and pull out while wiggling it you will be fine.
Will try...
UpstateLex
03-26-11 02:23 AM
