curious - what cold psi do you set your tires at?
Took delivery in February and the computer indicated 39 - 40 as delivered. I have not adjusted them downward. At 4k miles, last tankful was 31 MPG - 65/35 highway/local mix.
Air pressure won't affect uneven tire wear. Being out of alignment, worn shocks, and things of that nature are what negatively affect tire wear. Over inflating (at least past the manufacturer's recommendation) helps reduce wear on the tires, assuming properly aligned with good shocks, etc.
stevelifts
02-24-17 11:28 AM
