Map Screen after Phone Call
2013 RX with Nav:
After I make a phone call, the screen on my dash always goes to the Map Screen, regardless of what screen I was on before the call. Is this happening for everybody else too? I have the "automatically change the screen" option (or whatever it is called) unchecked in the personal settings, so this is something else.
I have 2013 Rx450h with Nav and I'm pretty sure it returns to whatever screen I was on - usually the Fuel Consumption screen. I also have the Auto Screen option turned OFF. I'll try to check it for sure on the way home tonite.
I'll try it from several different screens and see if it's consistent but I'm pretty sure it is. I do seem to recall that if I had the Auto Screen option turned ON it would always revert to the MAP screen upon call termination, or after some time limit no matter where I was. I found it annoying.
OK...I made several calls from various screens and it always returned to the screen I was on prior to making the call. Of course, in order to test that functionality I had to use the BT to make the calls as opposed to using the mouse/phone screen as the starting point. I also had Siri make a couple calls from my iPhone 4S. Again, it returned to the screen I was on after the "Call Disconnected" message. Are you sure you have the Auto Screen Change option turned off?? Or perhaps I am not emulating your circumstances exactly?
OK...YES, when I use a Speed Dial number it does go to the MAP screen when the call ends. I suspect this is because you have to go thru Menu/Phone/Speed Dial and it doesn't remember that far back...? I think the MAP screen is like home base.
I hadn't noticed this because I had not yet set any speed dial numbers. I have almost 2000 contacts in my iPhone and it only loads the first 1000. If you have more than 3 numbers for a contact it then creates a duplicate contact with the next 3 numbers and so on. Not a very clever implementation.
quepasafra
03-23-24 10:52 AM
