2012 RX350 and check engine light
Just got my 2012 RX350 2 weeks ago and the check engine light comes on. Turns out the dealer thinks a mouse got to a wire (in a harness) in my garage. They soldered the wire instead of replacing the very expensive part. Called Lexus Customer Service and no help there. I would have expected Lexus to replace the damaged part. After all, how likely is it that the damage was caused in my garage rather than their lot where the car sat for months. Not happy.
https://www.clublexus.com/forums/rx-...nger-side.html
A few years ago, my daughter and I drove her ES down to my parents home in AZ. A desert rodent chewed through a wire or two in her car. We didn't know that, it just started running poorly. The repair was not a warranty item and was very expensive at the Lexus dealership just to basically patch the wires back together. If they fixed your car for free, consider yourself lucky. Some of the wiring harnesses are so extensive that replacing them, may cause more problems than just fixing the wires.
In terms of how likely is it that the damage occurred in your garage, I'd say it is a possibility. I had a wiring harness damaged in my SC in my garage.
I'd say it's very likely it happened in your garage. I wouldn't expect them to cover that under warranty. Rodents are a pain, they can do a lot of damage very quickly. I suggest you set up some mouse traps in your garage.
I agree; rodents don't seem to bother new cars, but a lot of different smells in an engine that has driven all over including weeds which would attract them!! Be thanksful it was free; I would NOT want anyone replacing a whole bunch of wires on any car; on the assembly line they do it and verify all is correct!
I agree-replacing harness requires removal of many things,and dealer may not put those back together as good as assembly line did. If they soldered the wires, the connection should outlast the RX
Your automobile insurance might cover the repair subject to your comprehensive deductible.
Thanks all for the feedback. We've decided to be satisfied with the dealer fix as replacing the part, as several indicated, could be more invasive than the fix.
