how to take windshield wiper off
Old 06-26-12, 11:53 AM
txsm86
txsm86's Avatar
Default how to take windshield wiper off
I hope this is not a dumb question, but I just can't take the windshield wipers off the stem of my 2012 RX 350. I wanted to take them off so I could replace the wiper blade. Nowhere could I find a release botton like my other and older Toyota cars. So, how do you guys change the wipers? Thanks a lot.
Old 06-26-12, 12:26 PM
kitlz
No, I don't play soccer!
kitlz's Avatar
The easiest way to remove the wiper is to grab the very end of the insert and pull it down so it falls below the end tab., then slide it out. It's a little more challenging on the driver side since you can't flip the blade. So it's better to keep it low to the windshield. I put a cloth underneath to avoid scratching the windshield. Another thing, slide the slimmest end of the insert in first so the wider end is closest to you. I find it easier to remove that way because there's more to grab and it won't get caught in the things that hold the wiper in place.
Old 06-26-12, 08:25 PM
svofan1
svofan1's Avatar
...as a follow up.....this is the way you do it when replacing the rubber blade only, correct?...not the whole armature..thanks
Old 06-27-12, 03:10 AM
kitlz
kitlz's Avatar
Yes, correct. I haven't replaced the whole blade because I never had luck with aftermarket wipers. If it ain't broke...
Old 06-27-12, 04:30 PM
svofan1
svofan1's Avatar
...I agree...beside the blades are usually cheaper to replace than the whole armature.....in my case I don't only agree with you....I am scare and unsure about any aftermarket items in any car..specially in the RX..I am not that daring..<S>
Old 06-29-12, 09:24 PM
Sevn86
Sevn86's Avatar
Personally I really like the oem blades. Much better then the aftermarket ones.
Old 06-30-12, 08:51 PM
svofan1
svofan1's Avatar
Wink
...you see Naazim, sometimes we do agree... I am not that bad, right?....<S>>
Gs21
12-11-17 08:32 AM
GSLexTexas
12-05-16 11:17 AM
Lavrishevo
02-06-14 12:11 PM
Da Hapa
RX - 1st Gen (1999-2003)
23
12-08-09 01:14 PM
kidluvsole
12-07-08 07:49 PM
Quick Reply: how to take windshield wiper off
