Maplight replacement with
I want to change my front map lights from the ugly yellow bulb. How do I get to the screws underneath the SOS button? I have an 2010 without the SOS feature and the screws are exposed so it's easy to gain access to the bulbs. Thanks for your help.
My map lights are white LED. I changed all the other bulbs to LED to match them and like it much better. The cover on the big one comes off by pulling a bit on it downward closest to the windshield.
No, I don't play soccer!
It's easy to change the dome lights but I left the map lights alone because they're not easily accessible and look fine next to LED dome lights. Like MEP mentioned, use a pliable plastic card to undo the tabs that are around the cover. Here's some pics before I changed out the dome lights.
PirelliRC
ES - 6th Gen (2013-2018)
03-15-15 09:45 AM
racinghart
01-08-07 09:43 PM
BottomsUp
11-28-06 10:45 PM
