Manual shifting the automatic
nope. Especially because I have a hybrid and it doesnt really use engine braking for going downhill since the engine turns off anyways. But if I had the gas model, I would only use it for engine braking
Yep, I use it. Most often engine braking dropping off interstate onto exit ramp. Also occasionaly snow and ice conditions.
I haven't noticed engine braking not working when ICE not running, must become motor braking?
If you're going fast enough it will go into 5th when shifting from auto to manual rather than the default 4th.
The auto up shifting when in manual makes it hard to red line it...
Last edited by DunWkg; 08-06-12 at 10:56 AM. Reason: My comments are based on my AWD, not sure of FWD.
I have used it on occasion with our 2010 450h, and it is fun and useful. My problem is I'm so used to just putting the hybrid in drive, and easing on down the road, that I forget it's there. Our new 2013 450h also has the new sport mode, which will be something more to play with, although it is activated through the menu switch on the steering wheel, rather than using the shift lever, so a whole different topic.
it's not really manual..but a feeling/sensation of going through the different gears.
the +/- sign on your shift ****.. that's it
i just have to say this:
Shifting through artificial gear in a Gearless Transmission ( CVT ) seems Goofy!
