Show me your phone mount
#46
#47
Coincidentally, I just loaded WAZE yesterday and realized how much it heats up the phone. Unfortunately, I live in MA, so there are more days that the Heat is on than the AC.
#48
https://www.amazon.com/dp/B012EI4J3O...WXUQRKKW&psc=1
Also, could you show a pic with the phone on it? Thanks!
#49
I know what you mean about a sticky thing on the dash, but I had to give in. I did discover (because I didn't like the first place I put it), that it peels off very cleanly.
In the winter months where I have heater on (which in SoCal is rare), sometimes in order to cool the phone I just stick the phone into the "center console fridge cooler" with our LX570. If we are in our other Lexus vehicles, I will turn on the AC to cold for a few minutes in order to cool the phone.
#50
This looks like what I want, but I can't find it on Amazon. Can you show a link? Found this one, which gets decent reviews.
as for a picture, unfortunately, my camera is also my phone.
#51
#52
Where do you put your cellphone
I tried keeping in the cup holder by drivers door but on a long drive the phone gets too cold and shuts down
we have nav, but no traffic on the nav ( that a whole different matter )
i was just wondering were most people keep their phones
#54
#55
2 for $8 not bad at all.
#56
I'm **** about some things, and placing a phone in front of an A/C vent is a big no-no in my little engineering brain. Why? Because of the potential for condensation inside the case after riding around with a really cold backside and then hitting the our southern high-temp humidity when exiting the vehicle. Being rather hot-natured, I MUST have my air flow, and it's going to be cold!
I've decided that I'm going to use some of my leftover RAM mount components to make up a system with their 2-1/2" suction mount and a short extender into a custom fabricated deep black box to the left of the steering wheel (above the cup holder). The suction mount will be in the small triangular glass section between door frame and the windshield. It's going to be deep set to eliminate the side glare I sometimes get from either sunshine or other vehicle headlights on the left side of the car during interstate travel, and also to eliminate the reflection of the screen onto the interior of the driver side door window.. The deep set box will mount to the flat face of a RAM attachment and will be rectangularly funnel shaped with a deeper wall on the left side than either the top, bottom or right sides. I'll probably use some flat thermoplastic and custom cut/weld the joints to get the shape I want.
Shoot, now that I think about it, I might just build that little box out of some thin solid mahogany or cherry wood I have in the shop... something to sort of match the wood trim inside the vehicle. That would look classier, for sure.
The honest truth, though, is that the RXh is my wife's car, and I only drive it occasionally. When we go on our long weekend road trips, though, that's when I would really enjoy my creation the most.
#58
I live in a dry climate so I don't worry about shutting off the vent when running the AC. I do shut off the vent when running the heater though. Heat is the enemy of microelectronics.
#59
I've been using that vent mount for while now with my Iphone 6s plus. It works perfect for me. The magnet is strong enough to hold my massive phone easily. I actually like the vent cooling my phone. When using the phone as GPS and screen on all the time the phone can get extremely hot. I have actually had a phone do an emergency shut down due to overheating from being on the dash. So the phone cooling aspect is good in my opinion. I never blow hot air through the dash vents in the winter, I always use the feet vents only. I don't like hot air blowing in my face. So winter time has worked fine as well.
#60
