Last edit by: IB Advertising
Browse all: Tires and Wheels Guide
- Why is My Tire Pressure Light On?
Guide to diagnose trouble and recommended solutions
TPMS reset switch - easy way to find without looking
#31
Good Day All,
I would like to know, if is possible to enable TPMS on the 2013 Lexus RX450h, my car didn't came with one, but would really like to have that option enable.
Please let me know if this is possible.
Thanks
Thanks
#32
Last week-end I installed summer tires/rim. Without doing anything Tire pressures on the dash display works?????? My understanding was to push the reset button for TPMS and
relearn the TPMS ids. I am confused now. Also if anyone uses Autel MS401 can it do the programming after scan? Or is it just TPMS scanner?
#33
Are your winter wheels/tires stored nearby?
My 2013 reads my winter tires stored in the garage and starts to complain when I'm quite a way from home.
Do you have a reset button?
i don't - I thought those went away with the 3rd gen.
#34
Iwhen I was swapping tires, I removed winter ones , stacked them them one by one as I install summer ones. Then I moved winter ones away to tool shed.
Yes there is reset button under the driver side dash, right behind floor illuminating light. I did not push the button yet. At least no display for TPMS warning.
I will just drive like this and when winter tires are put back will see what happens. I suspect it is still reading winter tire TPMS(?).
#35
I'm thinking about getting new set of wheels & tires for my 10RX but I don't care or want TPMS sensors (more trouble than it's worth) is there an option to turn off the TPMS monitoring in the car?
#36
Share your trouble and lets see if we can address it.
Salim
#37
I don't know how to turn them off, but during the winter months when the other rims/tires are on the car, I use electrical tape to hide the light. I'm not bypassing anything or disabling the system. I even checked with my insurance company because I get a discount for winter tires and they said if I don't want TPMS, I don't have to have them as far as they are concerned. I do however check the pressure often during the winter months. Trac control and all other functions work whether TPMS is getting a reading or not.
#38
lexusblood, just to let you know the 3RX does not have a full spare or sensor. It's also located under the cargo floor. I believe in Europe though they get a full spare. Not sure about a sensor. The 2RX did and was outside.
ribster, TPMS is usually triggered when the pressure drops 6 PSI. It also depends on the pressure when reset. Try overinflating the tires a bit, hit the reset button, then adjust to the desired level. This way it doesn't drop dangerously low. The cold temps will definitely affect the pressure, In rare cases, the light can be caused by a bad sensor.
#39
Figured it out what's going on. Yes the car was reading winter tire TPMS stored in a tool shed in the back yard. From the front attached garage to the shed is quite a distance but I proved it by
letting air out on one winter tire which caused warning light. In a hurry I installed a copy of Techstream on my laptop and double checked it. When I drive away from the house PSI indication disappears and "Checking tire pressure" message but no warning light. When I tried to read TPMS id, with Techstream there was none. When I come home PSI readings start showing up and Techstream shows the TPMS id. I am waiting for Autel T501 to trigger and read summer tire TPMS ids. TP401 will be enough since I have Techstream now but TP501 was on sale for good price.
#40
I just had my Tpms reset for summer tires by a local independent shop FOR FREE.
Thought I'd ask if they could do it, and the tech said "sure," pulled out a SnapOn kit and did it. I didn't have the serial numbers with me - he scanned each wheel then plugged in the scanner.
I'd recently taken two other cars there for service but today I was just driving by.
And to reiterate a 2013 RX450h does NOT have a reset button.
Jonas
Jonas
#41
Jonas
Jonas
#42
In my area I find America's Tire very helpful. These guys will rotate, repair, air up, or whatever within reason without charge even if you did not buy the tires from them. Their goodwill had worked for me bc I bought multiple tires from these guys for the last several years. I used to get my tires from Costco or Sam's Club. But no longer. Better service and these guys will match any legit competitor's price anyway.
Jonas
Jonas
#43
The TPMS warning light won't turn off/reset on my Lexus RX 450h (2010). I have check all 5 tires including the spare and all are at/slightly above 35 lbs. I even tried the reset button under the dash. The light flashes when I first start the car and then stays on.
#45
WHEN TIRE PRESSURE WARNING LIGHT IS LIT
(a) When the tire pressure warning light does not go off, or when it comes on during driving, check tire pressure. If the tire pressure warning light comes on after adjusting the tire pressure, the tire may have a slow air leak.
(b) The system will be disabled in the following conditions: (When the condition becomes normal, the system will work properly.)
- The tires without tire pressure warning valve and transmitters are used.
- The ID of a tire pressure warning valve and transmitter has not been registered in the ECU.
- The tire pressure is abnormally high (absolute pressure: 600 kPa (6 kgf/cm 2 , 87 psi) or more; relative pressure: 500 kPa (5 kgf/cm 2 , 72.5 psi) or more).
- The battery of the sensor has been depleted.
Oscar58 (08-28-17)
