Fuel gauge accuracy ...
After reading thru these threads I haven't seen this particular issue addressed. If it was and I missed it, I apologize. The issue: I just purchased a 2010 RX450h with 60,000 miles. I also opted for the extended warranty so this problem will be taken care of by the dealer but just curious if anyone else has had this fuel gauge issue. When I first got the car and the dealer filled it up, the gas needle indicated about 2 needle widths above the full mark. As I drove the needle dropped normally. This same indication went on for about 3 fill ups so i assumed that was a normal totally full indication. Now for the last fill up I refilled the tank when the needle was on the second tick mark below the full mark; however the needle didn't go back the its original 2 needed widths above the full mark as before it stayed at its last position which was the second tick mark below the full mark. It stayed there at the second tick mark and seemed to move downward normally as I drove. I just added fuel again and the needle remained at it last position and hasn't moved to indicate gas was added but it does seem to move downward at a seemingly normal rate indicating gas is being used. I realize I probably explained this as clear as mud but if anyone can decipher this and has any experience with this issue I would appreciate knowing how you handled it. I will be calling the dealer tomorrow to set up an appointment to exercise the extended warranty.
dagomob (10-13-22)
How Accurate is Miles Left Until Empty?
My 2013 Lexus shows the number of miles until empty. Once it reaches below 20 miles left, it only says "Low Fuel". Today it reached that point and I drove about 15 miles before I reached a gas station. When I filled up, it only took about 15.5 gallons. The fuel capacity is 19.2 gallons which means I had just under 4 gallons left. At about 20 miles per gallon gas mileage, I had roughly 70 miles of gas left. Why does the indicator go into low fuel when it hits 20 miles left when it can go another 70 or so miles? It doesn't seem very accurate. Does everyone else have that issue?
in the Twilight Zone. I'm awfully tempted to drive around some time until the car stops running, but that's kind of a Homer Simpson move.
If in fact it is true that usable fuel capacity is only 16.2 gallons, the car's specifications should reflect that, IMO.
