Tired at looking at map--How change default setting
Hi, hoping someone has a step by step.....I have a 2013 350 w.the full nav package and the mouse controller. I noticed that when im on the radio page that after about 15 seconds it just switches back to the map screen. Then I have to either press the radio button or menu button and navigate back to the radio screen.....is there a personalized setting to make the radio page the default screen...I looked at the sheet for settings and didnt see anything...thanks in advance
you can also have both displayed at the same time... when on the nav screen, there should be an ON button, turn it on. Then there will be an option on the left side of the screen that appears, Menu something, go in there and it should be self explanatory. You can have it display other info alongside the map
