Looking for faster manual access to destination assist
Currently to manually access destination assist I have to press menu then select destination which brings up the map and no menu. Then I have to press menu again which brings up a selection for destination assist. Is there a faster way? I have a 2012.
Voice command "Destination" then "Destination Assist" or "Destination" then "Call Destination Assist"
Assuming you've acknowledged the warning or it timed out it, should be: <Menu>, <Destination>, <Destination Assist>, <Call Destination Assist>
If the map shows up, it's probably due to not acknowledging the warning as RXSF indicated.
Your right you have to press menu. Press destination. Press enter to acknowledge the warning. The map comes up. Press menu. Press destination assist.
Could this be made simpler? You have to press enter and guide the mouse 5 times!
well to be fair, if you had your nav screen on the map by default, you would be able to get the warning instantly when starting the car. then you would only have to click menu, destination, then destination assist.
No, I don't play soccer!
You can press the map button above remote touch to bring up the map screen. Press it a second time to eliminate the warning screen. Normally it takes a few seconds to go away on its own. Then press menu to get to the main screen. It's a little easier than using remote touch for everything.
Thanks Anita, that eliminates a step and less mouse movement. It's all about keeping your eyes on the road.
Possible, if Lexus would create a "reserved" or permenant contact in your address book / contact list. The call command brings up the phone's contact list.
