side window question
good day,
Yesterday when i went out to my rx450h for lunch i noticed all 4 side windows were open about 1 inch. did i butt dial a setting on my key fob? I know if you hold the unlock for 3 or more seconds all the windows will open fully including the moon roof, but see nothing in the manuels about a partial opening setting. of course i did come to work at 5 am so i may have been sleep driving and opened the windows myself, but sure dont remember doing this. so far this is a one time occurance.
Thanks
Mike
Thanks
Mike
No, I don't play soccer!
Hi Mike, did you check your moonroof to see if it's partially open? It might not be if the windows were only down an inch. You'd get a beep and 'moonroof open' message on the dash when you open the door if it was. Anyway, it's very possible your butt accidentally opened the windows because it only lasts as long as the unlock button is held down. You can use the key in the fob to close everything up. Insert the key in the driver side door and turn/hold to the left. Turning to the right will open everything up BTW.
thanks Anita,
no message about moonroof so i think it was still closed. i must have held the button down just long enough to start the windows.
my 39 day learning curve may turn into 39 months to learn al the gizmos.
cheers
mike
cheers
mike
phillies
01-17-09 10:42 AM
