removing and cleaning throttle body
Can anybody provide instructions along with pictures for removal and cleaning of throttle body on 2010 RX350?
Mine just turned 50,000.
I also ordered a K&N filter to replace stock one.
Any other maintneance items I can do while I have the engine shrouds all removed?
Just spray clean the throttle body while it is in place on the engine. No need to remove it if it is not broken. Get some throttle body spray, not carbureator cleaner as the tb spray will not damage any coatings inside the tb. Spray, scrub with an old toothbrush, open the throttle plate, spray farther back inside and scrub some more, let it soak a while before starting. It will run rough at first. If it throws a code, ignore it and it will go away in a day or two.
Basically get a rag and wipe all dirt and clean all around.
Spray all electrical connectors with an electrical spray.
Inspect vacuum hoses for fitting, condition of hose.
Inspect water hoses for fitting, any leaks, condition.
Drive-by-wire means instead of a mechanical linkage between the gas pedal and the throttle, it is now replace by electronic linkage and a microcomputer, you still need a throttle body. I am sure because you can buy a throttle body for an RX.
It also means it is inside the intake tubes and you can't snap it open easily like the traditional ones...
Buy throttle body intake cleaner spray. Remove air intake hose where it attaches to throttle body (be sure you know what a throttle body looks like and where it would be located). Be sure car is off. spray cleaner inside throttle body and wipe with rag. Have friend press gas pedal in car to open throttle plate so you can now spray further inside the throttle body and on the other side of the plate. Spray and wipe clean. Spray more and let sit. Wait 10 minutes to start car. Use this time to reattach intake hoses. It may be hard to start, wait until it idles smooth before driving off. Also add a bottle of Techron fuel system cleaner or Red Line fuel system cleaner to gas tank.
Not sure how this would work in the 350, but with drive by wire in the 450h, you can't even rev the engine. It's completely electronically controlled and in park or neutral the accelerator has no useful function. Only in drive or reverse does it even work. So with the engine off (or even on with the 450h) pressing or pumping the accelerator would have no effect at the throttle body.
It is possible if you put the hybrid system in "inspection mode". It's one of those put the shifter here, press the pedal, put the shifter there, press the pedal, spin two times with your left index finger on your nose kind of procedures. But once you do, the engine will stay running, and the gas pedal will allow you to raise and hold the rpm somewhat.
LOL, I think I'll leave that to the shop if necessary.
Flyingwrench (04-30-24)
I did the throttle body cleaning job, following instructions on this thread.
I also replaced stock air filter element with K&N filter.
I disconnected battery during this procedure.
Then I put it back together and took it for a "spirited" ride!
It certainly improved the response.
Now that our cars are 10+ years old thought I'd clean the throttle body. Mine has 170000km or 105k miles. My car at times had a hesitation from a slow rolling start. Cleaning the TB has seemingly improved this although it was just one test drive after this was completed.
Some videos on YT show removing the air box and disconnecting the MAF sensor. None of that is necessary on our model. Remove the air filter for some room and undo both clamps on the end of the intake hose and you can finesse it out of the way enough to access the TB. If you remove the big vacuum hose from the intake hose it's a real PITA to get back in so try and to it without would be my advice.
Happy cleaning!
Edit: just confirming after a day of driving and multiple trips out the hesitation on slow rolling starts I was experiencing is now gone.
Happy cleaning!
doji (04-27-24)
Curious if the wiper cowl needs to be removed to have easier access to remove the air cleaner box and get a direct shot to the throttle body? Just wondering given the tight space. Would like to attempt on mine with 145k miles. Still runs smooth and has the original spark plugs on.
