Door Sill
My wife would like me to look for sill protectors ..... unfortunately I cannot find any for the area she wants (see attached image)
Thanks in advance for your help and wishing everyone a Happy New Year!
No, I don't play soccer!
^^ That's about your only choice besides being very careful. I bought illuminated sills and kept the originals for when I bring in he RXh for service. They're super easy to remove.
I have them for another car, I stopped using them, I thought they were a pita. They are not hard to clean especially if you're careful not to scuff them too hard. Ive never seen them for the RX350.
I use that floor protector plastic to cover the sills when I bring it in for service.
If you go down to Home Depot and then go to their flooring department, you can find a roll of clear plastic that is designed to protect carpeting temporarily. It is inexpensive ($15-$20). It is called Roberts Temporary Carpet Protection Film. The roll is 24" x 50'. One side is normal plastic, the other side has an adhesive. You can just cut it to size, apply it and trim off excess. You can replace it as often as you want. You can leave it on the surface as long as you like. You can do the sills, doors, sill in trunk ... anywhere. After you install it, it will look like the clear plastic that comes on new cars to protect surfaces. It is pretty durable and can last months. It provides 100% protection. It leaves no residue when you pull it out.
I put it in my wife's car after she had back surgery. I told her not to worry about the car and just drag her foot across the sill if it was easier and not to worry about kicking the door accidentally. You can pull it out in a few seconds. When I take my car in for service, I do the door, sill, floor, mats ... everything. It is also useful for other projects in your home.
If you use it in the Lexus, cover the Lexus logo and even the paint in addition to the area you are indicating. When you install it, wrap it over the Weathertech mat lip and you will not get any dirt or moisture on your carpeting. I have WeatherTech's that I use in Subaru Outback for a few weeks out of the year for bad weather use and will wrap the sills when they are installed.
Here is a installation tip, cut the sheet outside of the car and simply place it on the area where you want it installed. If you cover the foot rest area, you can use the foot rest without getting your carpet dirty. If you switch to the normal mats in the summer, you can put the plastic down around the pedals where the mat does not cover to keep the carpeting perfect and make it quicker to vacuum your car.
If you're old enough
, you'll remember when your parents bought a new car and the mail box started getting filled with offerings from the 'FingerHut' seat cover company. They liked to put thick flexible plastic over the nice fabric seat covers.
My question is, have you used it in summer? I was actually impressed how flexible it remained when I installed it at temps around freezing, but I'm wondering looking forward what will happen if this stuff is left on during a really hot day when the interior temp will skyrocket. Not sure if I will need or want to use it in summer, but we'll see how things go. Having it go gooey in high heat remains a concern.
Acura2Lex
30
02-08-14 06:23 PM
eddo1
10-22-07 07:32 PM
